850 voltage regulator
palebird
Year and Model: 1994 850 Turbo Wagon
Post by palebird »
I need a voltage regulator for my 1994 850 T but I see two types being offered, one by Bosch 1197311520 and one by Huco 1197311234. Are they interchangeable or were there two different types of alternators/regulators fitted to these cars?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
What kind of alternator is in your car right now?
The majority of them use a Bosch alternator, but some were equipped with some Nippondenso-named thing. If you've got the Bosch, then you need the Bosch voltage regulator.
'98 S70 T5
2016 Chevy Cruze Premier
Been thanked: 472 times
Post by cn90 »
FYI,
Amazon now sells HUCO Voltage Regulator for $45!
https://www.amazon.com/Huco-W0133-166039 ... words=huco
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
I bought one of these $12 VR off ebay for my Mercedes (same alternator as 850). Holds steady 13.9-14.1v at all RPMs and electric loads. Plan to use the same thing on the 850.
http://www.ebay.com/itm/Voltage-Regulat ... 313wt_1273
Ambitious but rubbish
Paul240480
Year and Model: V70SE Auto. V70T5SE.
Post by Paul240480 »
I broke down in my 240, it was an alternator brush box issue. Bosch OE. The electricians place that my break down took me to fitted a HUCO replacement . It has been fine since, but it did not fit! They had to saw off a projecting bit of plastic to 'make' it go fully home.
Not sure if this would be an issue on yours, but thought it worthy of a 'mench'.
Post by cn90 »
tjts1,
Does it fit the Volvo 850?
tjts1
Post by tjts1 »
Paul240480 wrote:I broke down in my 240, it was an alternator brush box issue. Bosch OE. The electricians place that my break down took me to fitted a HUCO replacement . It has been fine since, but it did not fit! They had to saw off a projecting bit of plastic to 'make' it go fully home.
That mechanic is an idiot. The VR should pop right in if you compress the brushes. Without compressing the brushes it becomes a huge chore.
The 240 and 850 use different shape VR. 240 along with most 80s Bosch alterators looks like this.
850 along with most 90s Bosch alternators looks like this.
The important points about a VR is the shape and AMP rating. The 850 has a 100a alternator with the brushes sticking away of the solid state. Whether or not a vendor decided its specifically for your car and model year is pretty much irrelevant.
Paul240480
Thanks, at least it worked... I remember him scratching his head and holding the two VR's to compare. It was me that saw the difference and I said so. He chose to saw it, as you say if he'd simply held the brushes in it may well have slotted right in!
Any how, I am in danger of taking this off topic :oops:
