1996 Volvo 850 How do I remove the steering wheel?
FinnoSwede
Year and Model: 850, 1996
Post by FinnoSwede »
Hello Volvoers!
I already got tips on how to disable the SRS system, but now need to know the correct procedure to do the following:
1) Remove the steering wheel.
2) Find and clean the horn contacts.
I am asking here because every manual or procedure I have found have contradictions. So, if anyone that has performed this in the SAME YEAR-MODEL could give me a proper/detailed guide on how to do this, I would be more than thankful!
Thanks!
FinnoSwede
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Remove the air bag from the steering wheel.Turn the steering wheel so that the top is to one side.There is a hole in the back of the steering wheel.Insert a long T-30 and remove the screws for the airbag.Always remove and tighten the right side screw for the air bag first.If not then the horn might not work.Next take the little T-20 screw stored in the steering wheel.That will get screwed into the hole on top of where the bolt for the steering wheel is.It will hold the Contact reel from unrolling.
Note: Break the bolt for the steering wheel loose before installing the small screw.
Remove the bolt holding the steering wheel in.It is a 18mm head bolt.Then lift the steering wheel off.
Been thanked: 504 times
Post by cn90 »
You will likely need new clockspring.
All the detail is in this DIY:
DIY: 1998 Volvo V70 Clockspring (Airbag/Horn Contact Unit)
https://www.matthewsvolvosite.com/forums ... hp?t=34639
FinnoSwede
cn90 wrote:You will likely need new clockspring.
Hi there and thanks. The procedure you linked me to is for a 1998 V70. I have a 1996 850. Just HOW similar is the procedure?
THANKS!!!!!
FinnoSwede
rspi wrote:Remove the air bag from the steering wheel.Turn the steering wheel so that the top is to one side.There is a hole in the back of the steering wheel.Insert a long T-30 and remove the screws for the airbag.Always remove and tighten the right side screw for the air bag first.If not then the horn might not work.Next take the little T-20 screw stored in the steering wheel.That will get screwed into the hole on top of where the bolt for the steering wheel is.It will hold the Contact reel from unrolling.
THANKS FOR THE REPLY!!!
Oddbob
Year and Model: 1995 854 Turbo
Post by Oddbob »
I was going to post this: http://www.woodjoiner.com/volvo/VolvoEvapReplace.pdf, but they beat me to it (and theirs is better than my link).
The Good - 1995 850 Turbo
The Eh... - 2004 Ford Focus
The Dead - 1996 850 GLT - The bane of the Grand Cherokee..
FinnoSwede
Oddbob wrote:I was going to post this: http://www.woodjoiner.com/volvo/VolvoEvapReplace.pdf, but they beat me to it (and theirs is better than my link).
Hey that link is actually quite good, Oddbob, I will use it. Thanks!!!!!!
FinnoSwede
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
Just make sure you disconnect the battery first or you'll throw the SRS light which can only be turned off by a dealer. When the light is on, the airbag system is disabled. And always behave carefully - the airbag can go off without power if mistreated.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
1. When the airbag light is ON, it does NOT mean the SRS system is disabled. It means that an SRS fault code is stored.
2. The airbag can't be triggered with with the battery disconnected.
Ambitious but rubbish
vjaneczko
Post by vjaneczko »
1. - Sorry, but I trust the gospel according to JRL (and many others):
https://www.matthewsvolvosite.com/forums ... =1&t=42727
and another to read:
http://volvoforums.com/forum/volvo-850- ... ure-33735/
2. - Plenty of videos on YouTube showing people hitting an airbag and making it deploy without any power to the system.
Another good read: http://www.volvoclub.org.uk/tech/servic ... System.pdf
These systems are serious and every precaution should be taken when dealing with them.
2006 S60R - For ME!
