During summer the alternator died and so did the battery. After replacing both I have noticed that a-c off and rec lights flash for 20 sec on start-up...But everything was fine, fan works fine at any speed and I can direct air from any vents.
Until this morning....because it is geting cold up-here (Canada that is), now I know why it flashes, I have no heat coming in, just cold air.
This problem started with a dead battery and dead alternator while driving. Coolant is ok, temp gage is normal.
Looks like a damper is stuck on cold air or something, and it is the same thing on both driver and passenger sides.
s70, glt, 1999
ECC light flash after dead alternator
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I don't know if a home-made code reader for your ECC will help, but it certainly helped me on my 1997 855:
https://www.matthewsvolvosite.com/forums ... 5&p=251436
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No,it should be fully obdII system.rastarea wrote:Thanks jreed, yes I have seen this post, but does this led system works on a 1999 S70 ?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Here it goes, I smell trouble. After payment they inform me that they dont have it, but offer something else:
''thank you for your order. i am very sorry that now there isn't enough Volvo Dice in stock. but the Volvo Dice Pro is on sale and price is usd178. Dice pro has more Canbus than Dice. other funtion are all same. if you like it we can send Dice Pro instead of Dice to you asap and you only pay the same price with Dice usd140. about Dice Pro photo pls link http://www.aliexpress.com/item/2012-hot ... 87843.html
i really appreciate you can accept my advise. waiting for your response. thank you!
best regards.
Yolanda''
best regards.
Yolanda''
I got my Vida & Dice, it took only 4 days with DHL. But I did not make it work yet, I am struggling with the software installation. I borrowed a laptop from work and will try with a different computer this week-end.
- Year and Model: Lots
- Been thanked: 128 times
When you select the directory to run the patch to, don't select the Vida folder. Just run the patch to the root drive of C
- 19 Replies
- 5147 Views
Last post by theWIFES_S70
- 10 Replies
- 4984 Views
Last post by CRM
- 9 Replies
- 1041 Views
Last post by xnRS
- 378 Views
Last post by AlanHMultiV70s
- 1241 Views
Last post by oragex
