Quick Ignition question
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
travis873o
Year and Model: 1990 740T
Post by travis873o »
So if I've just replaced the starter and the vehicle does not start every time. when the key is turned to start nothing happens. Then I will repeat and repeat and repeat and finally the starter will get going and it starts right up. So if it is the signal going to the starter...
Is this the part I need to fix this problem:?
http://www.fcpeuro.com/products/volvo-i ... 40-9447805
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If the problem is the ignition switch that is the part you need. However, before splashing your cash do a quick check on the solenoid, the ignition switch and don't forget the PNP switch.
The attached is headed for the 240 but applies to the 740 as well.
240 starter does not crank engine.pdf
(136.19 KiB) Downloaded 116 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
