codes tcm e003 and abs 0095 help
99 s70 glt,have these 2 codes,i know what there for.but can anyone help me in what direction i should look for the fix.seems like a wiring problem.car runs great i need to shift it manually and put it in nuetral when comeing to a stop or it will feel like it will stall.it feels like it is stuck in limp mode.what be be a commen area to look for a bad connection or bad wire.i have checked all the grounds,removed sanded and put dialectic grease on all.procedures and pictures would greatly appreciated.thanks casey
- Year and Model: Many Volvos
- Been thanked: 76 times
It sounds like you have a couple of problems going on. The ABS code combined with the performance issues point to a bad ABS module. Matt at Midwest Modules can fix you right up. It also sounds like you have a bad PNP switch. That would cause the inability to start in park and it can also cause the transmission to go into limp mode. A temporary fix for that is to row the shifter back and forth, quickly, a couple of dozen times.
I'm sorry, I misread your original post and thought you couldn't start except in neutral rather than needing to shift to neutral. I will need to look up the transmission code to figure out what it specifically says but I am resource limited while on my laptop and out of the office. My bet is that there is a missing vehicle speed signal which usually goes back to the ABS module.kasey wrote:i have no problem starting in park or nuetral,there is no flahing arrow or ets light on,i have flushed transmission.still doing what its been doing.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
If the only abs codes that came up is 0095 I wouldn't bother messing with any of the wheel sensors. Thats a communication code, you dont have any wheel sensor codes in there.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
It's either the abs module or there is a genuine communication problem.
2000 s70 GLT
2014 Ram
I REMOVED ABS,TOOK IT APART AND RESOLDERED ALL THE PINS.BELIEVE THE LOCK UP TORQUE CONVERTOR SOLENOID IS STUCK ON.I CAN MANUALLY SHIFT IT AND IT WILL SHIFT WITH THROTTLE CONTROL UP AND DOWN.WHEN I COME TO A STOP IT WILL NOT UNLOCK THE CONVERTOR....CAN THIS BE A BAD SL SWITCH OR VALVE BODY PROBLEM.....ANYONE EVER HAVE THIS PROBLEM..PLEASE HELP.REALLY HATE TO SELL THIS CAR,THIS IS THE ONLY PROBLEM WITH THE CAR.
- 16 Replies
- 4453 Views
Last post by erikv11
- 3946 Views
Last post by packetfire
