car will not crank
car will not crank
I have a 1987 volvo 740 gle the car will not crank over.I replaced the battery and checked all the cables.I can jump start the car by using a wire from the battery to the solenoid need solution to my delema.I tried starting it in neutral also.No idiot lights when the car is running
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You didn't answer one of the questions. Your edit says "No idiot lights when the car is running".
Bill.
You can check the starting circuits:Do any of the idiot lights come on when the ignition is on?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
The reason why I asked about whether the idiot lights were coming on when the ignition is on with the engine not running is this: On my 1988 Volvo 760 Turbo Wagon the wires running from the positive battery terminal to the ignition switch had broken off from the battery terminal. The result is everything is dead.
