Is heating it my last civil method to remove what...
boosted5cyl
Post by boosted5cyl »
Yeah heat it. I had to do same.
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
Heat is your friend.
'84 Prelude
'06 MPV
'13 Ford Focus SE
db130
Year and Model: 2002 V70 T5
Post by db130 »
+1 on the MAPP gas torch.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
3" cutoff wheel and replace both the inner and outer...not worth the hours and hours you're spending trying to get that PITA nut off IMO.
1995 850 GLT Wagon w/ 200,000 miles
MilehighV70XC
Year and Model: '99 V70XC, 143,000mi
Post by MilehighV70XC »
Maybe I am misunderstanding what your trying to do. If your replacing both inner and outer, why are you even bothering trying to get them separated? Just get the inner loose from steering rack and remove as one piece.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
MilehighV70XC wrote:Just get the inner loose from steering rack and remove as one piece.
This.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
Been thanked: 504 times
Post by cn90 »
MilehighV70XC wrote:Maybe I am misunderstanding what your trying to do. If your replacing both inner and outer, why are you even bothering trying to get them separated? Just get the inner loose from steering rack and remove as one piece.
xHeart's initial plan was to replace the Outer only.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Lightbulb moment.
Pipewrench method by MiJ.
xHeart
Post by xHeart »
Haha!
A careful use of pipe wrench on inner tie-rod where it screws on to the rack.
inner-tie-rod screw point
removed as one piece
Notice the chipped edge while looking up. Does it need JBWeld to last?
Is this a deterioration?
notice a chipped edge
Post by cn90 »
It looks fine. That small chip is nothing to worry about.
Just cover the steering rack's end with ziploc bag and rubber band while you wait for new parts to arrive.
Dirt is the #1 enemy of the steering rack.
PS: During install, just remember to use some rubber material as cushion between pipewrench and the rack's end to prevent further chipping it.
I notice that your trans is also exposed. Get a piece of plastic/masking tape and tape the ends of the auto trans (I understand that you removed the axles for rebuild) to prevent dirt/debris/bugs from getting in. Even the slightest amount of dirt is the worst enemy of the auto trans.
