91 740 Radiator Fan on high
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
blynx
Year and Model: 740, 1991
Post by blynx »
I just replaced my speedometer with one from a pick your part on my 1991 740. It came from a 1990 740 and works well other than the miles on the odometer being different. However, after putting everything back in, I start the car and notice that the radiator fan is running on high, or it seems to be extremely loud. Could I have messed with something on the instrument panel and accidentally caused this? It stays on high if the key is in the II position or even when the car is cool from starting.
Thanks in advance.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I have attached wiring diagrams for the '90 and '91 instrument clusters. A careful check will show that the wiring differs in some parts - especially for the wiring coming from the temp gauge. On the '91 that wiring comes from A7 & A8. On the '90 it comes from B4 & B7, which will be causing the ECU to think that the coolant fan needs to be running.
740 '90 and '91 instrument cluster wiring diagrams.pdf
(912.47 KiB) Downloaded 105 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
