S80 radiator fan runs on high
Earn_est_89
- Year and Model: Volvo s80 2006
hey I'm having the some problems with my 05 S80 my AC doesn't work and the radiator fan is always on max like the car is overheating but it's not...does recharging the AC really work or do i have to buy a new radiator fan assembly?
I would first check to see if there is freon in the system if not then you need to recharge and it should fix your fan problem if yes you might have a faulty A/C pressure sensor that could keep the fan running on high as the computer is not sure what's going on and keeps it running so it doesn't over heat. but even if there is freon it could still be very low so adding about half of small can will not do much harm to test it.
please post your results back once you have it fixed so other searching the forum will have info need to fix their vehicle
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
Earn_est_89
**Update **
So I added some A/C lube and Freon to the system and the assembly fan quieted down...like a baby with a bottle..Big thanks to @vovo_merz for the help
- 1962 Views
Last post by Earn_est_89
- 5755 Views
Last post by oragex
- 1399 Views
- 1107 Views
Last post by BryonTheCanadian
- 1152 Views
Last post by Rocketny
