Volvo 850 heater core replacement 2
This topic is in the MVS Volvo Repair Database » Volvo 850 Heater Core Replacement Tutorial
Year and Model: Lots
Been thanked: 128 times
Re: Volvo 850 heater core replacement 2
Post by precopster »
IMy only question is: What are the part numbers for the rubber heater hoses that run from the coupler to the block?
Look up the hoses part numbers on FCP Groton's site under '99 model. They have no listing under 2000 model; at least not for the NA model. I brought it to one of their guy's attention but things being usual there.....
Used this heater core myself a month ago on my 2000 V70 na WITH NEW COUPLER and hoses. Job went like a dream.
If you're going to bypass the coupler pull the L shaped tubes out and use the old coupler as a grommet; saves the risk of chafing the hoses as they pass through the firewall which is something you definitely don't want.
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Thanks for the info guys. I will be buying the Ebay heater core - that is a ridiculously low price with good reviews.
I want to keep the stock coupler, etc. If it were my car, I might try something "custom", but since it is my future brother-in-law's, I would rather keep it stock.
I found the heater hose PN#s. Total for everything comes out to $182 (coupler kit and hoses from tasca). Not bad, especially since I started out with the assumption that the heater core would be >$100 on its own.
Is there anything else I am missing? Is replacing the heater hoses a logical thing to do, or is there alot more work involved? Hoping for a "Loosen clamp. Remove Hose. Install new hose. Tighten clamp." type of procedure.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Been thanked: 467 times
Post by cn90 »
That is certainly up to you.
Personally, if this were me:
1. Ebay heater core = $40
2. Heater Hose = $6 for 6-feet
Total = $46.
Permanent fix. Just inform your brother-in-law this is what you do.
This mod (bypassing the coupler) is 10x better than the factory junk.
If the Volvo engineers see this mod, they will be jealous!
mtd240
Post by mtd240 »
cn90 wrote:That is certainly up to you.
Total = $46.
Very tempting..I think I might give it a try. Saving $140 might be worth it :lol:
Gone:
Post by cn90 »
This is the DIY that you need:
https://www.matthewsvolvosite.com/forums ... =1&t=44948
See the pic by "erikv11".
mtd240
Post by mtd240 »
cn90 wrote:This is the DIY that you need:
Yeah I saw that - looks pretty simple. What kind of pipe cutter were you talking about using?
Gone:
Post by cn90 »
Ask any plumber and they will tell you they use pipe cutter to cut copper pipe for home plumbing.
Just tighten the tool, then rotate it, then tighten it, then rotate it until it cuts through.
It is $8-10 at Home Depot, get the mini cutter so it fits better in that space.
http://www.homedepot.com/Plumbing-Plumb ... ogId=10053
Youtube has some videos. The tool is very easy to use.
Total = $46.
Sorry to nitpick but you forgot the price of 2 extra hose clamps for the cabin side costing about $1.50 each so around $49 all up. These couplers below are ready to protect hose.
You can cut the metal pipes a little shorter and get a great looking noise cancelling grommet which looks factory made. Fits 5/8 hose perfectly.
With a bit of pulling and penetrant spray they gut very easily.
mtd240
Post by mtd240 »
I am thinking that the only reason Volvo used the method they did (metal pipe to coupler to rubber hose) was safety. It leaves the weakest link, and the most catastrophic failure mode (rubber hose exploding/popping) in the engine bay. Putting the metal pipe in the cabin prevents a catastrophic "boiling hot coolant hose explosion" from happening right at the driver's feet/legs.
Will do some more thinking on this..
Gone:
That's very good analytical thinking and certainly food for thought. In RHD countries it's on the passenger side so not as catastrophic an event if this happens; at least not for the driver. As hoses age I can see the lazy scenario happening: "if it ain't broke, why fix it?" until one day.........
Honestly who is going to do back contortions to replace hose every 2-3 years, spill and recover coolant just to be safe? We're replacing our heater cores because they're broken. The same can be said of any other ongoing repair work on 10+ year old cars.
