OEM wheel bearing - early failure
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: OEM wheel bearing - early failure
Post by jblackburn »
65 Nm and then an additional 60 degrees. Do them in a star-shaped pattern.
See the attached document for more.
s70 wheel bearing.pdf
(847.83 KiB) Downloaded 606 times
'98 S70 T5
2016 Chevy Cruze Premier
nzvlnr
Year and Model: 1999 s70t5
Post by nzvlnr »
The bolt I was referring to was the one bolt on the first page of your diagram, last photo. The single bolt in the center. Does this hold the rotor on and has to be removed? What does it need to be torques to? THANK YOU FOR THE ASSISTANCE!!!!
jblackburn
89 ft-lbs and then an additional 60 degrees. Or pretty much as tight as you can possibly get it with a breaker bar.
'98 S70 T5
nzvlnr
Post by nzvlnr »
This bolt holds the rotor on or I do not need to touch? It looks like it holds the hub assembly to the drive shaft?
jblackburn
It does. What did you loosen? Just tighten back up whatever you loosened to the specs either there, or in the document above.
'98 S70 T5
nzvlnr
Post by nzvlnr »
Such a newbie I am ....Now I am all stressed that I will screw it up.....I had my car in for a " brake and lamp inspection" and the shop would not pass it because the rotors were too thin. So I am installing new brakes in the front so and i didnt see a good DIY document on changing the front brakes.......I am doing this to obtain a salvage title for the vehicle...
jblackburn
This is what I used:
http://www.freewebs.com/dacvolvo/brakediscsandpads.htm
You don't need to remove anything besides the pin on the FRONT of the rotor to get it off. Once you've got that off, it's held on by rust. Beat the crap out of the rotor with a sledgehammer from behind and you'll break it loose.
If you still have questions, please start a new topic.
'98 S70 T5
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
cn90 wrote:Update,
I learned about this F.A.G. and TIMKEN marriage yesterday LOL.
Kind of a sweet surprise!!!
Believe it or not, the BEST price I found was $82 for the Volvo Front Bearing from "Stockwise Auto"!
And yes, TIMKEN HA594181 has F.A.G. Bearing inside the box (I checked it with my own eyes when I visited my local Autozone store!).
Two TIMKEN boxes arrived today, it is stamped F.A.G. - Made in Germany, for two dollars more.
xHeart
Post by xHeart »
Heavy.
I will install one at each front wheel. Looked closure at its character and compared the two, there are plenty of rust speckles and burn marks all over it. But one shows a visible shaved surface, see below. Would it throw-off anything since this topic is about "early failure".
Front Hub/Bearing Assembly - TIMKEN HA594181
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
The visible "shave" you refer to showed up on some genuine Volvo brake rotors I installed. I questioned the parts supplier about it and was told it is a balanced part and the shave is done to balance rotational weight (kind of like putting wheel weights on to balance a wheel). I was somewhat skeptical as I had never encountered same with any brand of aftermarket rotors I have used, but I did not notice any wobble attributable to an out-of-balance condition so I assume it is fine.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
