Update,
Purge Valve Bosch 0280142300.
Took it out (it sits between the battery and the radiator).
- Two Torx screws later, it is out.
- Changed all hoses (old hose...dry rot)
- The old hoses bonded to the line, so used a utility knife and slice it gently along the hose to split it.
- Blow through valve (NOTE the arrow), it blows right through!
Should have been closed when out of the car.
- No need to disassemble the valve etc.
- Spray Carb Cleaner into both ports.
- Repeat this 10x until no more black gunk comes out
- Now blow through the port (again Note the arrow), it is shut.
So the Carb Cleaner trick did the job!!!
- Installed, all is good.
Anyway, just want to share this FREE fix with you guys!
How to test and repair your EVAP valve:
How to Test and Repair your EVAP Valve
JeffersV70
- Year and Model: 1998 V70
I'm going to have to try this, I've been running a p0455 code for 2 years now.
1998 V70 N/A / Red / 127k
1998 V70 N/A / Black / 109k
- Been thanked: 504 times
You will see that when you remove the Valve, it blows through. The closing mechanism has gunk build-up inside (see the photos at the beginning of this thread) that prevents it from closing. So it stays open all the time, thus the P0440 code.
Once you clean it with carb cleaner, you will see that the valve now closes properly.
It has been a few days, and the code P0440 is gone (usually this code comes up within 1-2 days).
So I am happy about this free fix.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
What was the cleaner, brand?cn90 wrote:Attached is the photo of the Purge Valve Bosch 0280142300 for those who want to take it out and clean it:
Dirk1966
- Year and Model: V70 2.4 D5 2004
I was looking for this purge valve on my ME7 . Should it be a similar item or is it different?
Where you have the purge valve in the picture i have a different item.
On my car i found a square Valve?
Item codes
7.22517.01
12V 98T294
9125243
Item codes
7.22517.01
12V 98T294
9125243
marshappynation
- Year and Model: 850 1996
- Has thanked: 2 times
There seem to be at least 3 purge valves for the 1996 850. I don't know what dictates which yours will have. One attaches to the cannister (FCPEuro part 9135805). Two attach to the radiator shroud: Bosch 0 280 142 300 and 0 280 142 302. Those look similar outside but are different inside. The suggested repair procedure is based on the 302. My car, a 1996 850 non-turbo, has the 300. It doesn't have the o-ring so I didn't try to repair it.
songzunhuang
- Year and Model: 98 V70 T5
- Been thanked: 30 times
The glue on mine was so permanent that I cracked the housing trying to pry it apart. Also, I had no evidence of an o-ring! Did it disintegrate with age? I tried to RTV the inside and epoxy the case, but I am doubtful. I think a new valve may be in my future. We will see. Thanks for the tip none-the-less.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
songzunhuang
JeffersV70 wrote:I'm going to have to try this, I've been running a p0455 code for 2 years now.
Haha, I think mine has been more than 2 years. I even took it to the dealer to get it "fixed". It lasted a few days - long enough to pass smog inspection test, but then would always come back. It'll be interesting to see if this is the solution for me.
Song Huang
Can this fix be adapted for the square purge valves from a v40/s40? Has anyone had any luck fixing these ones? If so-any information or instructions would be greatly appreciated.
- $_35.JPG (7.96 KiB) Viewed 4994 times
- 1003 Views
Last post by jreed
- 957 Views
Last post by legacyhunters
- 15 Replies
- 4391 Views
Last post by MrAl
- 1063 Views
Last post by Paul-93-850
- 15 Replies
- 2072 Views
