Transmission "lunge" when coming to a stop...
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bojified
Year and Model: 2003 XC70, 2004 S80
Post by bojified »
1992 940 GL B230 NA with AW 03-70L 3 speed auto with OD. 142000 miles.
This car is fairly new to me but as you can see in my sig I am not new to the AW trannys. Right after I purchased I did all fluids including a 'flush' with the iPd hose of the transmission. I have had the car since October and it is my DD. The tranny shifts great while in motion. All the shift points seem appropriate. When coming to a stop 9 times out of 10 just as I am coming to a complete stop (literally in the final few feet) the car lunges as if hit from the rear. If I get in a hurry and don't come to complete stop- as I push the gas to go there is even a bigger jolt and the engine RPMs get drug down then I go and everything is fine. It did this when I test drove it. Also even though there was a recipt from a reputable local indy shop that the fluid had been flushed two years ago it was quite brown. The flush I did seem to not change the shifting issue.
It seems to be as the tranny is shifting into first- or out of OD as with the NA engine and the 4:10 rear end the OD comes in in town driving and the torque converter "Lock up" is tied into the same system because if you relase the OD by the switch (which shuts off the solonoid valve as I had another NA redblock with same tranny and did the cheap drill out of the solonoid passage).
This is not an electronic tranny and there is no computer involved unlike my 2003 CHrysler TC which had to have MOPAR fluid or it acted in a similar way.
My questions are:
Has anyone else encountered this and if so is it the OD or the torque converter....or a sticky ball valve?
I am tempted to re-flush with syn fluid however I am not sure syn has any more detergent action than a name brand DEX III.
Thanks
Scot
2004 S80 Wife's daily driver. Still have, 2003 XC70 T Daily Driver. Still have, 1997 854 Kept going for daughter, 1992 944 - Diplomat Delivery, 1997 855, 1989 744 saved my life!, 1987 744 T, 1988 780 BERTONE, 1988 765 T, 1987 744 T, 1981 244 DSL, 1974 164, 1976 265 PVR, 1981 264 GLE, 1971 145 DL, 1976 245 DL
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Maybe the lock-up torque converter.
1988 Volvo 760 Turbo Wagon
bojified
Post by bojified »
Thanks for the reply.
Yes the more I process the problem the more I also think it is the converter unlocking.
Matbe look for a different converter?
Thanks
Scot
