First Time Ever 240 Dead, No Spark
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
kelley40
Year and Model:
Post by kelley40 »
Backing out of my drive and my 240 died on me! Only 242000 miles on it.I have no spark can anyone tell me where to start?Fuses all look good.new rotor plug wires.Not sure about coil maybe they dont go bad often.Anything go out in the 240s? Been the best car ive had besides another 240!
Thanks for any info!!!!!!!!!!!!!!!!
Ron
Reason: Please -- no ALL CAPS titles. Thank you.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
What year is the car?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
kelley40
Year and Model:
Post by kelley40 »
1992 240 sorry
billofdurham
Ignition coils do fail but are easy to check.
Using an ohmmeter, check the resistance between the side terminals of the coil. Do this with all of the wires to the coil disconnected. You should see 0.6 to 0.8 ohm of resistance. Then check the resistance between either side terminal and the centre high tension terminal. The reading should be 6,900 to 8,500 ohms. Any significant deviation from these numbers would indicate that the coil is defective.
Also to be checked are the earth (ground) connections on the intake manifold for the power stage and control unit. They should be clean and tight.
Bill.
Previously:
kelley40
Year and Model:
Post by kelley40 »
Thank you BILL!
I'm getting mixed readings so i'm taking it to work and let a guy check it!!! I hope thats what it is!
Thank you......Ron
kelley40
Year and Model:
Post by kelley40 »
.9 is the reading. autozone says good coil .rotor is turning.Hate to send it to the crusher! I drive this 240 more than the 850 volvo or the corvette!!!
kelley40
Year and Model:
Post by kelley40 »
Cleaned some connections changed #6 fuse and she started!!!!!
Thank you Bill for the help!
billofdurham
Good news. Thank you for the update.
Bill.
240 ignition amplifier check.pdf
(171.96 KiB) Downloaded 243 times
Previously:
