94 960 srs fault codes?
I have a 94 960 150k with an srs light on and I would like to know if there's any way to retrieve the fault codes via the OBD.I can't seem to find the info on this particular problem....thanks in advance
- Year and Model: Lots
- Been thanked: 128 times
Right up high in the dash there's the SRS module close to the steering wheel. On top of the module is a plastic 10A fuse. With a very long nosed plier you can reach it and replace it if blown. My '93 model 960 had this problem and once replaced never reappeared in 3 years of ownership.
I found the resource telling me of the location on Brickboard.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You can use the OBD unit. Instructions are attached.
I shall also pin the instructions at the top of the forum.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
A million thanks Bill,you've saved an out of work construction guy a lot of money on my 94 850 as well as my daughters 94 960 over the past year.I am grateful for others feedback as well.Without this site I'd be using public transportation.
