94 960 srs fault codes?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
318mike
Year and Model: 850,1994
Post by 318mike »
I have a 94 960 150k with an srs light on and I would like to know if there's any way to retrieve the fault codes via the OBD.I can't seem to find the info on this particular problem....thanks in advance
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Right up high in the dash there's the SRS module close to the steering wheel. On top of the module is a plastic 10A fuse. With a very long nosed plier you can reach it and replace it if blown. My '93 model 960 had this problem and once replaced never reappeared in 3 years of ownership.
I found the resource telling me of the location on Brickboard.
318mike
Post by 318mike »
Thanks precopster I'll check the fuse,but I still wonder how to check for fault codes and if it can be done via the OBD under the hood.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You can use the OBD unit. Instructions are attached.
960 SRS Diagnostics and Testing.pdf
(3.91 MiB) Downloaded 196 times
I shall also pin the instructions at the top of the forum.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
318mike
Post by 318mike »
A million thanks Bill,you've saved an out of work construction guy a lot of money on my 94 850 as well as my daughters 94 960 over the past year.I am grateful for others feedback as well.Without this site I'd be using public transportation.
