Problem after transmission fluid change
Francois850
- Year and Model: 97 850 Non Turbo
Hello, I replaced the transmission fluid on my Volvo 850 non turbo, I used the recommended fluid etc. proper quantity. This was a preventive maintenance operation, transmission was fine but fluid looked dirty. Mileage was about 35K on it. Since then, the transmission shifts fine but, the car won't accelerate well, clutch is obviously slipping and I am lucky if I reach 40mph. When the transmission is cold, it acts just fine but it deteriorates rapidly within minutes. Any clue what I can do to improve things? I heard some additives may help but... My C.E.L. is not on and I have no codes. Thanks in advance, I am really bummed out!
JDS60R
- Been thanked: 3 times
Please check the transmission fluid level. Let us know where it reads on the stick (the readings will be different on each side of the stick are you going by the lower one or the higher one?)
Retired
Francois850
I did and followed the Volvo procedure (engine running etc...) and it's just fine.JDS60R wrote:Please check the transmission fluid level
Francois850
I used the "hot" side and it was good. I drove the car prior and transmission was hot.JDS60R wrote:Please check the transmission fluid level. Let us know where it reads on the stick (the readings will be different on each side of the stick are you going by the lower one or the higher one?)
Francois850
Initially I used DEX / MERC Valvoline, was told to change it to Mobil 1 Synthetic, either way it was the same exact result... Don't think the fluid is the issue here...JDS60R wrote:Which fluid did you use?
JDS60R
Tell me about the level on the dipstick. Many times they enter at a steep angle and some mistake the high reading on the backside as correct instead of the low level on the top.
Retired
Francois850
You are correct, I noticed that, the level (where it's wet) is often different on each side, so which one to pick?JDS60R wrote:Tell me about the level on the dipstick. Many times they enter at a steep angle and some mistake the high reading on the backside as correct instead of the low level on the top.
- 16 Replies
- 3541 Views
Last post by fourteen2hands
- 1225 Views
Last post by robrike
