This is kind of what I was suspecting. The cover for the connector is missing and you can pull the terminals right out. You need to check if the wires go to the right location. I took a snapshot of the arrangement from the Volvo diagram, I just happen to to look at this, because I'm doing the same thing as you. Check this out, it's for a 98:
I hope this helps.
S70 ignition switch question
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Re: S70 ignition switch question
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Wow! That's a great wire schematic(factory OEM always is). I've been using Mitchell Thanks for your help guys.
So the question remains: Which wire carries battery voltage to engage the starter motor? The R-SB?
The OE diagram doesn't line up perfectly with the actual vehicle. I do not see the markings that represent the Yellow wire w/ white stripe? I have not sent battery voltage down either wire yet, I want to now which one powers the starter for sure before I test. Thanks Guys
1995 850 GLT Estate -190k
1998 S70 -233k
2003 VW Jetta 2.0L -130k
1994 Saturn SC1 -288k ..and still going strong
1969 Ford Bronco 302 -119k
1998 S70 -233k
- Year and Model: Many Volvos
- Been thanked: 75 times
The Green / Red wire typically powers the solenoid on the starter (it does on my 850s). That makes sense from the switch diagram as well since the Green/Red is associated with pin 50 on the switch.
I'll give that a try today...at some point.
This vehicle also has a few other problems...I've been reading that they could be related....
The power windows do not work, ever. (I can jump the power window motor to raise and lower the glass. So its an electrical issue.)
The power locks do not work when commanded from the door switch. They will however work when commanded with the key FOB.
Now, I bring this up only becuase I have a hunch they are related to the Ignition Switch failure. Well, not a hunch actually...I read the Schematics & Diagrams. I also found some reading on afew other reliable technician oriented sites I use. ( IDENTIFIX & iATN) I'll post the links to these sites below, However you may need a membership. (I think one of them is free).
Can anyone confirm this corelation between Ignition, Power Door Locks & Power Window Switch Electrical Failures?
It looks like the Door locks are a part of the circuit...but the Window Switch?
I would really enjoy seeing this Volvo Driving & working properly. I have put a lot of effort into this machine. Someday I will tell the story of how I came into this particular Volvo and my overall facination with Volvo's in general.
Again, thank you to whomever is putting this site together. It's nice to have this wealth of knowledge all in one spot.
1998 S70 -233k
1998 S70 -233k
1998 S70 -233k
1998 S70 -233k
travelling man
- Year and Model: s70/1998
Gentlemen,
I am completely confused after looking at the wiring diagram. My care to remove the cap to get to the retaining screw had only 3 wires move, 2 completely out: Y & BL/R and BL/Y loose next to Red.
So my switch wiring from the top of the 'D' (where the wires come in) counter clockwise;
BL/R, Y, R, BL/Y, N/C, R/BK, GR/Y, Y/VO, Y/WT.
It looks like I have the Y and BL/R reversed but the N/C is a different location, diagram has N/C after Red, mine is after the BL/Y. Also, I have a Y/WT to GN/R on the diagram.
I thought I had 2 wires reversed due to the fact that the engine continues to run until the key is removed. Strange or neat? Suggestions?
Jim
S70/'98
Jim
S70/'98
- 936 Views
Last post by VolvoFredNY
- 997 Views
Last post by FLXC90
