Another thought re alarm system. I am not familiar with the inner workings of the S70 alarm system but in general, there are 2 aspects:
1. Sensors (hood, door, motion etc.)
2. Module (rarely goes wrong)
The sensor issue: have you looked into hood/door sensors? Maybe they need a quick fix?
No voltage from ignition to starter troubleshoot (1999 S70)
Whitebird
- Year and Model: 1999 S70 Base manual
Ok, I will try that. I had a terrible time trying to get the connectors loose from the module yesterday; I gave up when I had this thought: "This module is a computer chip thingy. How do I know jumpering B:21 & B:22 would even work? Maybe it grounds B:21 when it reads a voltage on B:22 instead."cn90 wrote:You have 2 options:
1. Look at the Alarm Module and somehow bypass only the module, which means a jumper between B21 and B22 in the photo.
This will effectively bypass the Alarm but not the neutral safety switch.
Any tips on disconnecting the module? I can't see obvious tabs on the connector and nothing I push seems to release it.
I'll definitely look there. Thinking about it now, I know the module is not totally fried, because its other functions still work (door locks, fuel cap door).cn90 wrote:2. Buy used Alarm Module on ebay for cheap.
I hadn't considered this because I thought, based on the schematic, that only the ECM affects whether the alarm module will ground B:21. This is my first time using schematics, so I'm very new at this. Do you think another sensor that isn't on the schematic could affect the B:21 grounding?cn90 wrote:Another thought re alarm system. I am not familiar with the inner workings of the S70 alarm system but in general, there are 2 aspects:
- Been thanked: 467 times
If you go to ebay and search "98 Volvo S70 Alarm Module", you will see some Modules for sales.
This will give you an idea how to disconnect it.
