Timing Belt Change
Japedo
Year and Model:
Post by Japedo »
The ipd cam holder posted says its only for 1998 and prior "without Vvt"
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
mandomex1
Year and Model: 2004 V70 2.5t
Post by mandomex1 »
I did my 2000 V40 a while back and my 04 V70 recently via the Fcp Groton youtube video and a few diagrams. I will admit it was a bit stressful without locking cams but it came out perfect! Good luck!
2004 V70 2.5t 111,xxx miles
1990 240DL stuck at 158,xxx miles
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
The only hazard is if someone turns the crank shaft while the belt is off. (Hide the car keys!)
The only other thing that would cause the crank to turn is when you loosen or tighten the damper bolt, and that will only be done when the either the old belt is in place (for loosen) or the new belt (for tighten) either time of which the cams will turn with it.
Japedo
Year and Model:
Post by Japedo »
I am considering doing some work on volvo's
For customers in my spare time.
So I built the cam lock for added assurance when working
On other people cars.
I've done 3 in the past without a cam lock. But now I won't be nervous about it being off a tooth or something..
Don65Stang
Post by Don65Stang »
I've read both a 70k and 100k mile change interval. So which is correct for an 04 V70 2.4L?
2004 V70 - my daily driver
2004 Ford Excursion - family car
2005 Mustang Vert - wife's daily driver
1965 Mustang Vert - my first car
(2) 1971 Mustang Mach 1 - my fast cars
(2) 1972 & (1) 1973 Mustang Mach 1 - fast cars I'm restoring with/for my boys
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
105K
Technically if you read your owners manual Volvo changed to a 120K mile change in 2004.
Personally up to and thru the 07s I do them at 105K, the 70K change is up to and thru M/Y 1998.
I don't trust either a belt or a tensioner to last until 120,000 miles
Don65Stang
Cool. Thanks! I just bought the car, an 04 V70, and will take delivery on Wednesday. One thing I do with every car is read the owner's manual from cover to cover. I'm kind of geeky like that but there is a lot of very good info in the OM.
