Rear Brake lights kaput?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Baltovolvo
Year and Model: 1993 940
Post by Baltovolvo »
Stumped Easily on this deceptively simple problem-
checked all fuses (good), checked the bulbs (good, no breaks in the filaments anyway)
and do not know what to do next. Is there an internal computer that may have fuzzed? Do I have have to trace the wiring all the way from whatever voltage source powers the lights?
All the other rear lights work.
Stumped :oops:
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I am moving your post to the RWD section so that you can get more expert help with your car.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Does the high level brake light work or have you lost all three?
If you have lost all three it could be a faulty brake light switch. This is easy to check by removing the two connectors and connecting them with a jumper wire. If the brake lights come on it is a faulty or dirty switch.
If you have lost only the two lower brake lights it could be a faulty bulb failure sensor which you will find on the relay tray behind the front ashtray. It is the round unit on the back row of the tray.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Baltovolvo
Wow-Thanks guys, I will put that knowledge to use. Meanwhile, How do I keep from getting my gas stolen like it was last night? I have a locked gas cap, but these guys must have used a bumper key because the cap wasn't damaged. I check the cap every time I go somewhere, so if it spins (left) like it should when I've locked it, I don't worry. However when it starts to unscrew, that means it's been unlocked....
