Good Afternoon,
Wanted to post a quick question... When replacing the water pump... should I use a gasket adhesive or not... It appears the original gasket did not have adhesive... was installed dry.
Has anyone had an issue with the water pump leaking around the gasket when installed properly but without gasket adhesive?
I would normally put a thin layer of Copper Coat on the gasket...
Thanks
Water Pump Gasket - Adhesive Yes or No
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I just did one yesterday, no sealant just dry. If it makes s you feel good then use it.
The one I did yesterday was with the engine out of the car. It knocks the whole t-belt job down to 30 minutes or less.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
MattHenning
- Year and Model: XC70, 2001
I usually put anti-seize on water pump gaskets to make the next replacement easier.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
There is a step-by-step write up by cn90. Take a look for ideas.
- 636 Views
Last post by bmdubya1198
- 966 Views
Last post by Worrad
