Water Pump Gasket - Adhesive Yes or No
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
xk150
Year and Model: C70 LPT 2004
Post by xk150 »
Good Afternoon,
Wanted to post a quick question... When replacing the water pump... should I use a gasket adhesive or not... It appears the original gasket did not have adhesive... was installed dry.
Has anyone had an issue with the water pump leaking around the gasket when installed properly but without gasket adhesive?
I would normally put a thin layer of Copper Coat on the gasket...
Thanks
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I just did one yesterday, no sealant just dry. If it makes s you feel good then use it.
The one I did yesterday was with the engine out of the car. It knocks the whole t-belt job down to 30 minutes or less.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
MattHenning
Year and Model: XC70, 2001
Post by MattHenning »
I usually put anti-seize on water pump gaskets to make the next replacement easier.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
There is a step-by-step write up by cn90. Take a look for ideas.
