LED Headlight Kit ?
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
MattKas
Year and Model: 09 C70
LED Headlight Kit ?
Post by MattKas »
I was wondering if anybody used Plasmaglow or any other brand Bright LEDs undernight the headlights on C70 2006+ (mine is 2009) if yes, how did you route the wires and where did you hook up?
http://www.plasmaglow.com/lightning-eyes-headlight-kit/
Thanks, in advance,
Matt Kas
2009 C70
San Clemente, So Cal
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
You could connect them to your parking/running lights (turn on your light one click and see what lights up). That way they'd be on as parking lights and also with the headlights. Or you can tie them in to the headlight circuit and they're only on with the headlights.
If you want to get creative, you can tie them to the running/turn-signals so they're on with the parking/running lights AND flash when you hit the signals.
I don't know the wiring on a C70 so I can't tell you specifics, but a volt meter tracing wires from the bulbs and back will tell you the easiest spot to connect them.
MattKas
Post by MattKas »
Yes I connected them to the parking lights. Thanks. Matt
