What next? HPT 2.3 engine mod ideas needed
daltar08
Year and Model: 850 platinum 96
Post by daltar08 »
I have a volvo 850 turbo (1996 HPT 2.3) my mods are as follows.
IPD Short ram w/ K&N
Samco intercooler piping
IPD turboback exhaust
Ard Green @ 17psi
Silicon IAC outlet hose
Car is very fun handles well enough for me currently, pretty darn quick. My question is: what, if anything, do i do next for the engine performance aspect of my Volvo. I was thinking MBC but I hear those are dangerous. any suggestions are welcomed. Thank you.
Reason: improved title
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
I have an MBC, but no chip. Seventeen psi is seventeen psi whether it's attained via tune or MBC. Assuming other paramaters are the same. Which they probably aren't, because MBC is just a brute mechanical trick and doesn't remap fuel/air beyond stock maps, for instance. I get fuel cutoff at 17-18 psi.
That's a general order of additional things I'd do.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
My reading comprehension failed me again. Didn't see you need suggestions on just engine enhancements until I re-read your post.
Also -> Amazon link
daltar08
Post by daltar08 »
Regardless of what i said originally your response was incredibly helpful and well put. What's the story with the "turbo kit" and the picture of what i assume are turbo kit-esque parts.
Thank you
matthew1
Site Admin
Post by matthew1 »
Oh, injectors, before anything else. If the system can't get fuel in to keep up with all the other variables, the engine will be operating "lean", and that's very dangerous. Lean means not enough fuel, thus a lean mix, thus high temperatures.
Gasoline injection cools the engine. When you have a low fuel:air ratio, cylinder temps can skyrocket, and rods or pistons will fail. Rich means your front O2 sensor will die in a few hundred or few thousand miles, and your mpg will suffer. If you have to pick, pick rich. :wink:
The Monster Turbo Kit I mentioned above is a product of RZ Design, run by guest Fast Friday author Rye Z. It's not cheap, but the components look to be excellent. He's worked quite a bit recently with Lucky, owner of ARD and creator of your Green tune.
Also -> Amazon link
daltar08
Post by daltar08 »
Ok, so based on my mods list and the fact that i just placed an order for a boost gauge (now able to monitor pressures), what's the best (cost effective) turbo i can upgrade from the stock 96 850 turbo without having to change much of anything else in the engine bay and what kind of gains in performance should i theoretically expect with such a change.
For instance what kind of gains will the 18t give me over the stock 15g
matthew1
Site Admin
Post by matthew1 »
Is everything Stage 0 or close?
Ignition good?
Spark plugs good?
Note: I'm not on RZ Design or Lucky's payroll :-). I don't have any deals with either of them to promote their products. I've never gotten any products from them, paid or free, though I might get an ARD tune one day.
Consider my recommendation of the "Monster Turbo Kit" (my phrase) to be a generic recommendation, I'm not specifically advocating for that kit. Maybe there are better kits out there, who knows. I just know Lucky and Rye through the Volvo community and I respect them.
Regarding 15G vs. 18T vs. 19T it's a slippery slope due to their nature. You don't want to do all the homework/buying/installing just for a one-increment upgrade. You want to get more if you're going to all the trouble. When I get to this stage, I'm going 19T.
Keep in mind you'll want to send your ECU back to Lucky to get updated for the larger turbo.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
850wagont5 wrote:You don't need larger injectors, I ran my T3/T4E on stock injectors with a careful eye on the wide band, and it was fine at 1 bar.
Orange?
I think the OP has left the building, but it's a good thread. Thanks for your thoughts on 18/19Ts, 850wagont5.
Also -> Amazon link
