I have searched and searched for a fix to this issue, but to no avail. During my search, I have found numerous Volvo owners with the same problem, but no answers.
On my 2004 S60 2.5T, with the Bi-Xenon headlight option, the right side bulb went out. I ordered a set of D2R bulbs and replaced both sides. After the careful and proper install, both sides worked well. Later that evening, both sides went out and the message center says "Bulb failure-Low beam".
Thinking I may have gotten bulbs from a bad lot, the seller was kind enough to send another pair. Still no work, and same message.
I checked all related fuses, both inside the cabin and under the hood. I also pulled the CEM down and checked the shunt connector, but all looks new.
What are the odds of losing both ballasts at the same time?
Before I spend my paycheck on a set of ballasts, I pray there is something else going on that I can fix. Any ideas would be vastly appreciated.
04 S60 HIDs not working
StreetKing
- Year and Model: 04 S60/87 244/90 740
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Not sure why you lost both HL, do you have any lights (lows, highs)? If you have a digital meter you can check for shorts at the bulb, bulb removed. If there are no shorts at the HL then you can check for voltage. Put meter on volts, key in pos 2, check for battery voltage at the HL connector. If no voltage is found try the 2 fuses in the CEM. A wiring diagram will be very helpful, can find one on the net. If you do have battery voltage at the HL connector and no light then your ballasts are gone - but I doubt that.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
StreetKing
Thanks for the reply. I don't have hi/lo beams. I have the motorized reflectors that look up for hi and down for low beams. DRLs work, as does oem fogs. Everything works but the actual headlight bulbs. I heard the voltage can't be checked at the bulb because the bulb socket is actually a hi voltage igniter. But I don't know for certain...I know it's an igniter and it's hi voltage, but unsure if I can safely put a meter on it.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Yes both can fail at the same time.
Your car uses Valeo LAD5GL ballasts that are used on other makes and models.
I got two new ones not long ago for $115 each.
StreetKing
Thanks. I'm afraid to order them, in case that's not my problem, but I may have to.jimmy57 wrote:Yes both can fail at the same time.
draser
Again, you can measure voltage at the connector - see wiring diagram, which is only battery voltage. That'll tell if you if a fuse is blown or not. If you do then it's the ballasts.
StreetKing
Ohhhh...are you talking about unplugging the igniter and checking voltage at the connector?draser wrote:Again, you can measure voltage at the connector - see wiring diagram, which is only battery voltage. That'll tell if you if a fuse is blown or not. If you do then it's the ballasts.
draser
Looking at the wiring diagram I see a 5-pin connector for each headlight assembly. That's a good measuring point. The ballasts/igniter, etc are downstream from there.
draser
Here's the wiring diagram for the HL. You can see the connectors coming from CEM, and the fuses that power the hi/low's. The high voltage happens in HL assembly, past the conn. Good luck!
StreetKing
Thank you much. I will have a look.
- 2021 Views
Last post by Ozark Lee
- 2016 Views
Last post by EngineeringBloke
- 885 Views
- 1789 Views
Last post by kdaide
- 1729 Views
Last post by ajr91
