Oil sump (pan) o-rings job.....
rerobin66
- Year and Model: 2000 S80 T6
- Been thanked: 2 times
What we found on the tube going into the filter housing. One jacked up o-ring.
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
1964.5 Ford Mustang
2000 S80 T6
- Has thanked: 2660 times
- Been thanked: 1254 times
Oh man, that's bad. Doesn't seem possible that it worked its way into that position.
rerobin66
It was the only seal that seemed bad but we replaced all that were included in the kit. It was a major job. Doing this was very good education as to the anatomy of this car. And education isn't cheap or easy! lol
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
1964.5 Ford Mustang
2000 S80 T6
rerobin66
It by far was the most difficult job we have had to do on my volvo. But doing it once makes thinking about having to do it ever again...not that difficult. After jacking up the front end, the entire engine does have to be hoisted from the top. We used a come along and lifted it from the trusses in our garage. The eyelet on the right side of the motor was enough of a support to hold it. The entire subframe has to be dropped. Removing 4 main bolts and a few smaller ones to accomplish this. The oil sump shares a couple bolts with the transmission, but once you remove the 20 or so bolts it comes off fairly easy. There was a good thread in a different forum site. http://volvoforums.com/
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
1964.5 Ford Mustang
2000 S80 T6
matt5112
- Year and Model: 1999 S65
- Been thanked: 3 times
One thing I'm curious about is how many bubbles on the dip stick is too many.
Currently I'll see about 5-10 very tiny ones.
My last car just sloshed oil into the pan and always had a fair amount of bubbles on the stick when running. So to me, the concept of perfectly bubble free oil is surprising.
I'll probably end up doing the job regardless as a preventative measure.
JDS60R
Any bubbles is too many. If you are having these issues you should stop and fix the issue. Oil with bubbles in it does a horrible job of lubricating. The work you do now will increase your longevity.
Retired
rerobin66
I haven't seem bubbly oil in my volvo. Make sure your sump pan in sealed good. you have to use the chemical gasket. Search bubbling oil in these forums for more info
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
1964.5 Ford Mustang
2000 S80 T6
matt5112
This is what I needed to know. I have the parts, and I just need to make the time.JDS60R wrote:Any bubbles is too many.
A better question is where does the dip stick measure the level? It must be a very secluded spot in order to be completely bubble free.
Seems like a very mixed outlook on how difficult it is to do. Seeing as some seem to believe many things are impossible without special tools or lots of work such as changing the siren module or the accessory belt, yet I've found them to be much easier than described, I'm hoping this is one of those repairs that goes that way.rerobin66 wrote:I haven't seem bubbly oil in my volvo. Make sure your sump pan in sealed good. you have to use the chemical gasket. Search bubbling oil in these forums for more info
- 1005 Views
Last post by theWIFES_S70
- 1530 Views
Last post by jamadams
