v70 engine swap
Re: v70 engine swap
Yes, Does That Mean My Head Is Warped Beyond Repair. I Was Hoping It Was Just A Blown Head Gasket...
jimmy57
- Been thanked: 320 times
You would have to remove cylinder head and do some checks.
Severe overheat on aluminum block engines can allow the block to distort. The head and block top and head surface need to be cleaned to know if the damage is severe or if the engine can be repaired.
Did the coil cover or timing belt top cover melt to head?
jimmy57
That's not good. Usually (not always) when that melts, the aluminum breaks bond with the steel cylinder and the cylinders drop a few thousandths. No way to keep that from having a head gasket leak.
- Year and Model: Lots
- Been thanked: 128 times
Not from Volvo. Google Darton sleeves.
- 934 Views
Last post by MadeInJapan
- 15 Replies
- 4829 Views
Last post by soulvoid21
