1999 s70 cruise control and lock in gear feature issues
Beginning a week ago, my cruise control started shutting off on its own at random and my car begaan to slip out of the lock in gear feature on the highway. Anyone had an issue like this? I believe they may be related. Perhaps a bad stop light switch?
1999 s70 AWD LPT
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
First, check the atf level and color. The car coming out of torque converter lockout, which turns off the CC by the way, can be caused by high temperature ATF. I am surprised that the message center didn't say anything...
Klaus
Thanks for the reply! Level and color good. I swapped trannys 10k ago. I actually have an auxillary transmission fluid intercooler installed in line with the stock one as well as a filter from IPD in the same line. If problem persists, I may remove these aftermarket parts in case they are causing a flow issue
1999 s70 AWD LPT
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You are correct - the stop light switch is making intermittent contact and doing this!
It's just above the brake pedal - take it out and clean the contacts and adjust the plastic part of the switch as necessary to make full contact with the brake pedal when not pressed on.
'98 S70 T5
2016 Chevy Cruze Premier
- 2175 Views
Last post by Reinie
- 725 Views
Last post by NHVolvoNut
- 1315 Views
Last post by enotslim
- 2780 Views
Last post by DeadEric
- 11 Replies
- 2794 Views
Last post by dyn blin
