94 850 Turbo Erratic Boost Problem
jdt1249
Year and Model: 850 Turbo, 1994
Post by jdt1249 »
Hello,
on my 94 turbo sedan I'm having an issue with boost. At times the car will boost fine, right up to about ten pounds while other times it only wants to hit around 5. From what I have read I am thinking either the tcv or the cbv. Stage 0 is up to date. The only thing that has varied is where I have gotten gas. Any help is greatly appreciated, thanks.
94 850 Turbo Sedan ~223xxx D.D
97 850 NA Sedan ~265xxx Needs Transmission
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Sorry this topic has been overlooked.
I would think this is due to a weak spring in the CBV, but definitely check out the shape of all vacuum lines from the turbo to the TCV.
'98 S70 T5
2016 Chevy Cruze Premier
jdt1249
Post by jdt1249 »
okay, i might end up replacing the cbv. others have suggested that some of the piping is bad and to just get silicones, any thought on this? the lines on the tcv have been upgraded to silicone
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2662 times
Been thanked: 1256 times
Post by matthew1 »
Does the boost vary during one single drive? Or is it a day-on-day-off thing?
Also -> Amazon link
jblackburn
If you're hitting the full 10 PSI at times, the pipes are fine, though it may be old.
Mine has blown through a couple of the original hoses, so the silicone ones wouldn't hurt, but I wouldn't expect it to fix erratic boost development - that's to do with the wastegate/bypass valve.
'98 S70 T5
jdt1249
Post by jdt1249 »
thanks jblackburn
and matthew1, it is a day to day thing, not the same drive
