Changing spring seats
drgswede1978
Year and Model: XC70 1998
Post by drgswede1978 »
I'm going to change my spring seats on the front this weekend. I've found a guide but it's pretty vague. Just wondered if anyone had any hints or tips to make it an easier job.
Thanks
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
It's the same as changing a strut
Has thanked: 311 times
Been thanked: 817 times
Here is an excellent guide:
http://members.shaw.ca/heeeeee/strut/
Be sure to buy OEM Volvo brand spring seats, most of the aftermarket ones fail quickly.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
A hint is to always have the spring compressors taking the force of the spring until the bearing plate or strut mount as it's known is fixed and torqued back on.
If the spring's force pushes upward on just the spring seat alone with its star nut the new spring seat may tear slightly which greatly lowers its life.
drgswede1978
Thanks for the replies. It doesn't look too difficult. Will I need a wheel alignment after changing just the spring seats?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
No.
Also -> Amazon link
drgswede1978
Ok. Thanks.
Warren561
Year and Model: 2000 S70 5sp Auto
Post by Warren561 »
drgswede1978 wrote:Thanks for the replies. It doesn't look too difficult. Will I need a wheel alignment after changing just the spring seats?
matthew1 wrote:No.
Really? Changing spring seats basically involves removal/installation of the entire strut assembly.
Doesn't this affect the camber & caster at all?
Yes.
What Warren said.
For that reason, consider replacing now, while you have the strut tower out, anything else on it in need of work.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
You should do an alignment.
I didn't after replacing a spring seat and this happened to my right tire.
'98 S70 T5
2016 Chevy Cruze Premier
