I'm going to change my spring seats on the front this weekend. I've found a guide but it's pretty vague. Just wondered if anyone had any hints or tips to make it an easier job.
Thanks
Changing spring seats
JRL
- Year and Model: Several
- Been thanked: 16 times
It's the same as changing a strut
- Has thanked: 311 times
- Been thanked: 817 times
Here is an excellent guide:
http://members.shaw.ca/heeeeee/strut/
Be sure to buy OEM Volvo brand spring seats, most of the aftermarket ones fail quickly.
precopster
- Year and Model: Lots
- Been thanked: 128 times
A hint is to always have the spring compressors taking the force of the spring until the bearing plate or strut mount as it's known is fixed and torqued back on.
If the spring's force pushes upward on just the spring seat alone with its star nut the new spring seat may tear slightly which greatly lowers its life.
drgswede1978
- Year and Model: XC70 1998
Thanks for the replies. It doesn't look too difficult. Will I need a wheel alignment after changing just the spring seats?
- Has thanked: 2856 times
- Been thanked: 1332 times
No.
drgswede1978
Ok. Thanks.
drgswede1978 wrote:Thanks for the replies. It doesn't look too difficult. Will I need a wheel alignment after changing just the spring seats?
Really? Changing spring seats basically involves removal/installation of the entire strut assembly.matthew1 wrote:No.
Doesn't this affect the camber & caster at all?
Yes.drgswede1978 wrote:Thanks for the replies. It doesn't look too difficult. Will I need a wheel alignment after changing just the spring seats?
What Warren said.
For that reason, consider replacing now, while you have the strut tower out, anything else on it in need of work.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You should do an alignment.
I didn't after replacing a spring seat and this happened to my right tire.
'98 S70 T5
2016 Chevy Cruze Premier
- 1935 Views
Last post by missmysaab
- 3866 Views
Last post by 98v70dad
- 69 Replies
- 12239 Views
Last post by enotslim
- 1032 Views
Last post by LOB
- 987 Views
Last post by polskamafia mjl
