I've got a problem with hesitation and cannot figure out which one of the sensors in the topic is the culprit. I wouldn't like to just change sensors until a faulty one is found, perhaps one of you can help me to find the problem. I try to be comprehensive. Thanks in advance!
Symptoms
Occasional hesitation with light(ish) load, slow speed, around 2000-2500 RPM for one year. Last 2 weeks, severe hesitation, the car went once into limp mode, reduced power (like the car had some 90 HPs...). Hesitation takes place also in highway speeds now and can last quite long, around 2000-2500 RPMs, again. If RPMs get higher than ~2300, there is a strange sound under load, which could be the turbo wastegate operating hard. When there is is no load (i.e. revving on a parking place), the sound is not there. When I park the car, it feels unusually hot inside the engine compartment. Idle is nice, not rough.(Silly me, I didn't read OBD graphs when the hesitation first begun
Suspects
* Throttle body, maybe not: When hesitation starts, changing pedal position doesn't end it. Also, test OBD graph of throttle position shows a nice curve.
* MAF sensor, definitely no: I misinterpreted an OBD code and replaced the unit.
* Vacuum leaks, maybe not: I checked with butane and I didn't find any leaks. Also, OBD long term fuel trim is too negative. Positive would indicate a vacuum leak since ECM would try to compensate with extra fuel.
* O2 sensor(s), no. 1 culprit: OBD graph looks really suspicious, see graphs.
* MAP sensor, no. 2 culprit: OBD scanner doesn't get any reading, see graphs. I checked with a multimeter, there is supply to the sensor. Also, I checked with a vacuum pump the sensor, reading stays allways zero.
OBD data
Error codes:
* I've only read "P0127 - Intake air temperature too high". If I reset it, it stays away for a while and then it comes back. Hesitation occurs even when the code is not there.
Things which are wrong in the graphs:
* No MAP reading (top/blue): It stays zero
* SHFRFT1/Short term fuel trim (bottom/red): There should not be 2 figure readings normally, I believe.
* LONGFT1/Long term fuel trim (bottom/green): It is -15% (lean condition/false lean), it sould be a 1 figure number.
* O2S11/O2 sensor in exhaust manifold (bottom/blue): It's current, I'm not sure how to interpret it. However, I saw earlier a lamba=2 reading for the sensor.
* O2S12/O2 sensor after catalysator (bottom/yellow): There should be nice oscillation present in the graph. Oscillation is not there even when idling with A/C etc. switched off.
Graph 1: Vertical bar where hesitation begins. Graph 2: O2 after catalysator is totally wrong. OBD curves, questions
* Range of throttle position reading is from 12% to 85%, is it normal for this car? That is the range reported be OBD.
* If a O2 sensor is OK, should one always see nice oscillation ~1/s, despite that some other component/sensor is broken?
* There is no OBD reading for MAP (it stays zero). There should definitely be a non-zero reading, shouldn't there?
If there was a MAP reading, I would go and replace the O2 sensors. But with no MAP reading, I'm not sure at all. Can behaviour of the 02 sensors be because of a faulty MAP sensor? Or could it be something else than MAP/O2s? Any help is greatly appriciated.
Cheers,
Jani
