850 T5-R Auto high rpm power?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Re: 850 T5-R Auto high rpm power?
Post by hausmeister »
Thanks, misha!
misha wrote: If it continues with long cranking i would replace the fuel filter.If the fuel filter doesn't help...it would be a bad check valve in the fuel pump.But...let's go with one thing at a time. :wink:
Ok, I already have a fuel filter waiting to be installed when there is nicer weather... Also ordered a TCV and Bypass valve replacement from IPD. I hope I will get it to run as it should, this car deserves it.
Sadly the car was not always in capable hands before, some things got fixed (badly), and there seem to be some electrical problems in there as well. Still a lot to do, but first I want to get the power back to normal.
Maybe I will show it in the thread you mentioned, but that is still some time off ;)
But, a real beauty it will never be :|
850 T5-R '95 auto Image
hausmeister
Small update to my car's issues / progress...
Replaced the Ignition coil before winter, this helped some. Ignition is now completely replaced, and the engine sounds a lot more awesome ;)
Car was resting until now (and was at the shop getting the heater replaced, replacement used MAF (threw some codes), and 1,2 other things I didn't want to do).
Today I tried to replace the old TCV/BCV with the IPD version. I'm feeling stuipd, but I need your help:
According to the IPD manual the TCV was not connected correctly, see this picture (old setup):
Red: Wastegate
Yellow: Bypass Valve
Blue: Intake
(what I marked as white comes from the bottom of the turbo)
That is wrong? According to the IPD manual and description on the tcv it should be:
Red: Turbo housing
Yellow: Wastegate
Blue: Intake
What I don't get is why is it connected to the bypass valve? shouldn't the red line go somewhere else?
I tried it both ways and it didn't seem to make a difference...
This is my first turbo car, any help is much appreciated!
hausmeister
hmm, according to this diagramm https://www.matthewsvolvosite.com/forums ... 22#p183722
the whole setup is wrong...
Where it the Bypass valve normally connected? In the above picture hose 20 should go to where?
hausmeister
Well I fixed it.
New vacuum hoses and connected them correctly. Set the wastegate. Car now boosts to ~1bar which is 14-15psi. :)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Well done!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
Hey. Did a lot of other Stuff on the car, should now be at about stage 0.
I made a small video of how it drives; I think it is still missing a bit of power, at least from the specs it should do 0-100 in ~7.5 seconds with the Automatic or 7.8, not sure which is right. Mine taks about 8 seconds, which isn't bad, but also not perfect. What do you guys think?
At least It sounds badass ;)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
Sounds great, agreed. Is it still boosting to 1 bar?
Also -> Amazon link
hausmeister
I think so, but only really in "overboost", and I only really get that in 3rd... so only at higher speeds. normally max seems to be around 0.8-0.9bar or so. I think boost is fine from what I read it should be. Also the gauge might not be totally accurate.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
It does indeed sound great. Love the roundabouts! I find these engines sensitive to ambient temps, for power developed
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
matthew1
Site Admin
Post by matthew1 »
hausmeister wrote:I think so, but only really in "overboost", and I only really get that in 3rd... so only at higher speeds. normally max seems to be around 0.8-0.9bar or so. I think boost is fine from what I read it should be. Also the gauge might not be totally accurate.
That's normal.
Boost is a good measure of health. Not long term health, but health right at the moment.
Given it's making a full bar, I believe she's giving all she has. Remember the car magazines beat on the cars they test to get their best times. Things we'd never do... dropping the clutch at 5k RPM off the line, etc.
Also -> Amazon link
