Not necessarily.
Remember, your car is 18 years old. The ABS module controls the ABS system, but isn't the ABS system if that make sense. You still have 5 other circuits. Four wheel sensor circuits and a pump motor circuit.
You have a 96 so you also have that flimsy harness at the pump motor.
Do it yourself ABS module repair. Topic is solved
Do It Yourself ABS Module Repair
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
CamZH
- Year and Model: '94 850 + '04 S60 R
Don't remind me !
When the ABS light comes on, should she be showing error codes ?
I've had no luck with OBD scanners and my 850, but got a Bluetooth ELM327 unit on its way which i'm hoping will work.
I'll be taking the 850 out and about over the weekend, so I'll be able to see how she performs.
fingers crossed !
fingers crossed !
2004, S60R
1994, 850 T-5 Wagon
1994, 850 T-5 Wagon
deepsouth
- Year and Model: 2001 Volvo XC70
- Been thanked: 11 times
Hey all--
Just did my second module repair (on my 1998 S70). Everything went smoothly. Put back together and speedo didn't work and ABS light still on. Checked the connections and found the hinge (main connector) wasn't seated correctly (side slides weren't pushed all the way in). Seated correctly all is well and no more tracs/ABS lights. Touchdown for another successful repair. AWESOME writeup!
Eric
Eric
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
2001 XC70, 129,000
Replaced my ABS Module on Saturday. Watched the video first on Midwest ABS site. Except for some scraped hands job went smoothly on our 98 V70 wagon.
Haven't seen the ABS Tracs light come back on in 5 days. Our brake pedal seems firmer.
Thank you Matt for your service. Having the correct socket was a Godsend. Luckily non of our bolt heads were stripped.
I removed my positive battery lead before I started.
$14 Craftsman small socket set
Removed corrugated pipe
Where the ABS sits on a 98 V70
The removed module
ABS area with the module removed
The removed module
98 Volvo V70 Wagon NA 101K miles, 96 SVT Cobra Mustang 43K, 90 Ford Ranger 162K
Just thought I would add my personal experience to the dead speedometer / ABS issue. So I removed the module which was simple enough with a short 1/4" ratchet and E5 Torx socket. That part is a 15 minute job.
After you remove the module it has some finessing to get the unit apart without destroying the case edges. There are four steel tubes that the E5 screws fit through. These tubes have a bite clip that helps hold the module seal closed. Using a sharp machinist chisel I was able to pry these off and save them for reuse:) Then I used two short but wide flat bladed screwdrivers to pry the module open.
Under close examination with 30x magnifying lenses I found many of the solder joints to be "cold" including the power pins. Now I have been soldering for 40 years so I've got it down and there are certain things I just do out of habit. In this case it included desoldering all the pins using a solder sucker (braid works awesome too). The key is to have a soldering iron that has enough oomph to get the job done. A skinny pencil tip isn't going to cut it. What you will end up doing with that is over heat the joints, foul the solder and ruin your chances for success.
Once everything was desoldered I inspected for copper damage to the board and thankfully there was none. To ensure the best power pin connection I took a knife and scraped some of the etch resist (the green stuff on the board) off down to bare copper around the power pins. This allowed me to apply more solder to the power pins and increase heat dissipation if the load spiked high.
All in all the job took me 90 minutes but now I have a happy V70R with a working speedometer. An additional note is that my car is a Canadian car and the dash lights did not show ABS or TRACS or any other such indicator other that the CEL or in my case LAMBDA light was lit.
Anyway that's it. Thanks for such a great repository of information.
Hyp
Hyp
Fail to plan. Plan to fail.
johnRogers0014
- Year and Model: V70 Xc 1998
xtrattitude4u
- Year and Model: 1998 S70 2.4l N/A
+1.hyp2bsqr wrote: In this case it included desoldering all the pins using a solder sucker (braid works awesome too). The key is to have a soldering iron that has enough oomph to get the job done. A skinny pencil tip isn't going to cut it. What you will end up doing with that is over heat the joints, foul the solder and ruin your chances for success.
I also desoldered the pins and the results are much better.
I used a 40 watt desoldering iron, and it seemed almost too much for the smaller pins,
but seemed barely enough for the power pins.
If I had to do it again, I would use a 30 watt on the smaller pins and a 50 watt on the power pins.
I got a tube of clear windshield silicone to seal up the board when I was finished.
This was one of the most enjoyable repairs I've done on my Volvo.
It saves you a lot of time and money to do this repair yourself, not to mention the safety factor.
Someone turned in front of me a couple weeks after this repair.
I just needed a new bumper after the accident, but it could have been worse without functioning ABS.
kaneelschep
- Year and Model: '96 850 2liter t5
I did this fix just before the summer and had no abs light come up again.
Then went for a holiday to a very hot country. 40+ degrees celcius.
During the 1000 miles trip the light came back on. And during the month of holiday it came on more and more.
Now when I start the light mostly goes off. But when i start again it stays on.
So I am afraid I will have to take it apart again.
What can I use to coat the electronicsboard up again??
Thanks!
Thanks!
kaneelschep
Ah. I just checked out the wiring and found that the seperate two-lined cable has completely deteriorated. Well the insulation that is.
Has anyone discovered how to get the plastic black cover of the Abs pump? Then I can renew the cable's insulation all the way.
