97 850R What is this mystery hole for?
mattman
Year and Model: '97 850R TurboWagon
Post by mattman »
Mystery hole in cam cover between plugs 3 and 4. It's flanked by 2 threaded bolt holes. Anyone?
Has thanked: 292 times
Been thanked: 765 times
This is a leftover hole, nothing goes there. It is in the top of every 95+ white block cam cover. It is sealed from underneath when the cam cover goes on, and won't leak oil.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The pre '95 cars had a vent pipe there that connected down the back side of the motor. I believe it connected to the EGR system.
rspi
Post by rspi »
Is the top of your cover really that clean? Why is that?
mattman
Post by mattman »
Just did the valve stem seals. Sprayed cam cover with aircraft paint remover then pressure washed...stripped off my cam position marks as well...duh!
rspi
Post by rspi »
Did you do the seals with the head on or off?
mattman
Post by mattman »
On, in car.
