Hi,
I have a stock '97 850R (except the 16" wheels) with 135,000 mi on it. I recently took out of storage and put back on road. Car driven very little over last 5 years. Had independent Volvo mechanic check it over and freshen up maintenance, essentially Stage 0 stuff. Using R as daily driver now 100 mi/day.
Anyway, car has started to stumble on acceleration at about full boost. I recently disconnected battery and discharged car side to ground thinking ECU reset. I also put bottle of injector cleaner in tank. I probably didn't reteach ecu properly if that could be cause for stumble. Car also seems to lug around 50-60 mph and 2000-2500 rpm not in boost. Don't recall if this was normal.
Possible causes and solutions for Stumble?
Thanks much
1997 850R Stumbles on Boost?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
What plugs are in it? Stumble at high RPM is usually blow-out on these cars - caused by using the wrong plugs for the application.
4th gear lock-up is around that speed. It takes a semi-hard press on the gas to get a downshift.Car also seems to lug around 50-60 mph and 2000-2500 rpm not in boost
'98 S70 T5
2016 Chevy Cruze Premier
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Check the intercooler connection at the bottom, really check it. I always thought mine was tight, but in reality once I tried to pull it off, it came off very easily. Are you running old gas in it? Maybe give the MAF a squirt of cleaner too.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
Check your air fiter too. My truck, which sits for weeks at a time, started running pretty bad. Turned out some critters built a condo inside the cleaner.
- Year and Model: Lots
- Been thanked: 128 times
At this age if the original leads, cap and rotor are fitted this would be another likely cause.
White powder marks on them are a sign they are arcing.
Leads are date stamped if they are Bougicord. Take a look and see if their build date is a match to the car.
Plugs, wires etc are all oem or better. MAF could need attention, i don't know.
Most likely vacuum leak, right? Lines are old, dry, cracked so.......
where can I get a "kit" with all the vac hose sises I need, and adapter fittings if any etc?
if no kit anyone have a parts list? I wouldn"t mind replacing all hoses.
thanks..
thanks..
- Year and Model: Many Volvos
- Been thanked: 76 times
Stylin Motors used to have a silicone hose "kit" which 3 or 4 different diameters of bulk hose (4mm, 6mm, and 8mm). As far as I know Stylin Motors is no longer a going concern and you still needed to cut things to length with their kits, they weren't pre-cut. Gates makes bulk metric diameter silicone hoses or you can just replace them with the less expensive rubber hoses. NAPA should either have them or be able to get the Gates hoses for you. Even Volvo will just sell bulk hose and let you figure out the length.
The only problem I had with the silicone hoses was finding correctly sized spring clamps. The silicone hoses have a smaller outside diameter than their rubber equivalents and I wound up buying clamps that were either too small or too large and then I bent them until they conformed to the hoses enough to hold them in place.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Do you get a check engine light? Any misfires? If not, then I would guess a vacuum leak somewhere. Whenever I have the same issue my CEL light goes on or flashes indicating multiple misfires. I have an n/a 850 and 2 turbo s70's and the turbos are very picky about their spark plugs. I would only go with O/E.
did you have the fuel filter changed? how much gas was in the tank when it sat? you can goto a parts store and get the vac hoses for your BCS/tcv. i think just those three lines may help substantially. you aso should consider doing the CBV vac line at the same time. if that hose is starting to weep out air, that valve could be leaking boost on loaded conditions.
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
- 11 Replies
- 1901 Views
Last post by erikv11
- 24 Replies
- 4534 Views
Last post by bmdubya1198
- 23 Replies
- 4606 Views
Last post by mika
- 19 Replies
- 3560 Views
Last post by Chapelgirl
- 12 Replies
- 5196 Views
Last post by dosbricks
