I was wondering if anyone can give me an idea how long it should take my Volvo to reach operating temperature? I have noticed that it takes about 10 minutes to reach operating temperature and about 5/6 minutes to blow hot air out. My G35 (2006) heats up a lot quicker.
I've replaced the coolant and thermostat, but that hasn't seemed to help. Any other things I can check or is this normal?
2000 S70 Time to reach operating temperature
- Has thanked: 1613 times
- Been thanked: 4078 times
My gauge reaches 3o/c position in 5 minutes under 30 mph town driving.
You won't get warm air from your ECC until the coolant temp tells the ECC its "warm enough" which is a secret Code in software kept in a safe in Sweden next to the formula for a Coke and the Area 51 inventory.
- phils94850
- Year and Model: 2009 s60 turbo
You forgot KFC secret recipe as well..
1996 Platinum Edition
...that one was released by Snowden on Xmas....
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Within a few minutes. What thermostat did you install?
JRL
- Year and Model: Several
- Been thanked: 16 times
On a cold winter morning, yours sounds about right.
It takes my 07 about 4-6 miles or 10 minutes+ to get to operating temp
I used the "slightly better" Stant from AdvanceAuto. I was having the same problem with the OE thermostat.rspi wrote:Within a few minutes. What thermostat did you install?
2000 Volvo S70 Base - 125K Daily Driver
2006 Infiniti G35 Coupe - 125K Daily Driver
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
G35 has a much, much bigger engine than the Volvo
More displacement, more gas injected, more cylinders = more heat.
4-5 mins for heat is normal, ~8 to reach OT.
'98 S70 T5
2016 Chevy Cruze Premier
burnout8488
- Year and Model: 1999 S70 AWD
You'll get heat out of the vents faster if you load up the engine more. With the ECC set to AUT fan, and 72º, I can get a gust of hot air blowing out within 3-4 minutes if I drive a certain route. 40mph on a slight uphill road really gets the engine warm quick, even if I'm extremely gentle getting up to speed.
Remember, the oil takes much longer to heat up than the coolant, so go easy on the engine for 7-10 minutes, even if the temp gauge says "operating temp."
But, my Volvo heats up faster than any other car I've had. Gf's non-turbo heats up just as quick, if not quicker.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
You know I didn't even think of that, lol. Kind of like comparing apples to oranges I guess, but I was just wondering if that time frame is acceptable and looks like it is.jblackburn wrote:G35 has a much, much bigger engine than the Volvo
