1992 240 DL Reasons For Missing Overdrive
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Maximum Turtles
Year and Model: 1992 240 DL Wagon
Post by Maximum Turtles »
I got a used wagon (260,000 mi) a few months ago in pretty good condition, but I've been making minor fixes as I go. I was in the middle of trying to fix the overdrive, which I had determined had a faulty relay, when I found that the car's relay had been removed. I located the harness, but the overdrive relay was nowhere to be found.
I want to get the overdrive working again, but I was wondering if there was a reason for the overdrive to be missing. If someone had removed this intentionally, what kind of problems could have driven them to do so, and what dangers would I risk inserting a new relay?
I am willing to make some fixes and do some very lighting digging around to find symptoms, so any ideas you might have will be very helpful.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I'm not going to be the only one to ask this: But, what transmission?
1988 Volvo 760 Turbo Wagon
Maximum Turtles
4 speed automatic, can't believe I forgot to mention that.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
One possibility: the relays often fail in way that the relay will go from OD back to third and vice versa at will with no input from button on gear lever.
Maximum Turtles
In that possibility, would a new relay face any of these problems, or is the problem more than just a failed relay? Thanks for the response.
lummert
Post by lummert »
Seven years ago I replaced the overdrive solenoid with a bypass plate from IPD. Disabling the overdrive lock out hasn't caused any problems for me.
Maximum Turtles
I got a cheap new relay, plugged it in and its been working fine for a couple weeks now, I'll post if there are any problems in the future.
