I got a used wagon (260,000 mi) a few months ago in pretty good condition, but I've been making minor fixes as I go. I was in the middle of trying to fix the overdrive, which I had determined had a faulty relay, when I found that the car's relay had been removed. I located the harness, but the overdrive relay was nowhere to be found.
I want to get the overdrive working again, but I was wondering if there was a reason for the overdrive to be missing. If someone had removed this intentionally, what kind of problems could have driven them to do so, and what dangers would I risk inserting a new relay?
I am willing to make some fixes and do some very lighting digging around to find symptoms, so any ideas you might have will be very helpful.
1992 240 DL Reasons For Missing Overdrive
Maximum Turtles
- Year and Model: 1992 240 DL Wagon
Maximum Turtles
4 speed automatic, can't believe I forgot to mention that.
jimmy57
- Been thanked: 320 times
One possibility: the relays often fail in way that the relay will go from OD back to third and vice versa at will with no input from button on gear lever.
Maximum Turtles
In that possibility, would a new relay face any of these problems, or is the problem more than just a failed relay? Thanks for the response.
Maximum Turtles
I got a cheap new relay, plugged it in and its been working fine for a couple weeks now, I'll post if there are any problems in the future.
- 892 Views
Last post by warmblood58
- 701 Views
Last post by vtl
