The upper motor mount bushing needed replacing so I ordered one from the local Volvo dealer (part# 9434263). I was expecting it to be quite a job because everything I've read online says it is a VERY tight fit to get the bushing into the mount. The bushing I received fits in the mount VERY easily (if I suspend it with my hand I can get it to where it doesn't make contact with the mount). Everywhere I've looked online points to this being the right part, but I don't feel like it should be so loose. Does anyone have experience with this? Is there some kind of sleeve that goes along with it? Any advice would be great.
Thanks, Ken
2000 S70 Upper Motor Mount Bushing
Here are some photos. You can see how easy it is to move from side to side. I can also move it up and down a little. Do you think is correct? If not what did I do wrong?
- UMM2.jpg (16.62 KiB) Viewed 853 times
- UMM3.jpg (15.1 KiB) Viewed 853 times
- UMM1.jpg (33.84 KiB) Viewed 853 times
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
_
It should fit fairly snuggly (mine ipd blue) to being pressed in!
https://www.google.com/#q=part%23+9434263
Here a few photos to compare it with.
https://www.google.com/search?q=2000+s7 ... B300%3B300
_
_
- MoVolvos
_
Side to side, up and down is OK. Thought you meant it the entire bushing was loose in the bracket.
_
_
- instarx
- Year and Model: XC70 T6 2011
I have never understood why people spend hours pressing, fitting and struggling with replacing just the bushing. You can replace the entire aluminum mount assembly for about $20 and it takes 15 minutes.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- MoVolvos
(+1) Absolutely, positively will not work. Wrong part!januwan wrote:
it is not going to work...
_
JRL
- Year and Model: Several
- Been thanked: 16 times
That style started in 99 and goes thru the 07s
Just buy the entire assy
