98 V70 T5 codes
volvo v70 Chris
- Year and Model: v70 1998
I have a 98 V70 T5 and have a check engine light. I used a code reader and got codes p0455, p0102, and p0172. My research leads me to a large evap leak and maybe a bad mass air flow sensor. Would they be related? I would appreciate if somebody could point me in the right direction.
- Has thanked: 311 times
- Been thanked: 817 times
p0172 is usually just a vacuum leak, the MAF may or may not be having issues. Start by tracking down and fixing all vac leaks. Then clear the codes, see what comes back.
volvo v70 Chris
What is the best way to search for and fix vacuum leaks? I am not experienced in doing this.
Visual inspection first. There is a large J hose that fits on the evap canister that often tears. Get the car up on stands or Ramps and look with a flashlight ..follow the hoses on the path back the canister
On my 99 this canister lives back by the right rear wheel.
Check the purge valve hoses too , under the radiator plastic lip, driver side. Follow these back as well.
Find that vacuum leak before you chase those other codes. It is common to have a large leak throw a MAF code on a good MAF
It takes 100 miles of driving to run the evap test loop so you need a week driving in between resetting the check engine light and knowing if you have fixed it!
volvo v70 Chris
I looked for this evap canister and did not see it. Does anybody know exactly where it is on a 98 V70?
Check under the driver's side fender, you have to look up from underneath. The other location is back near the fuel filter, but that may be more common on an 850.
You can check the vacuum hoses in the engine bay for leaks by spraying them with starting fluid. If the idle surges, then the spray hit a vacuum leak. No substitute though for careful visual inspection.
Purge valve maybe?
The evap canister is a black box about the size of a Bible.
King James, not Douhy
That's a nice diagram, note also the shape of the canister, will help you recognize it when you find it. The diagram shows the "near the fuel filter" option but don't give up if you don't find it there, check up front too.
- 19 Replies
- 10195 Views
Last post by Barledge
- 1855 Views
- 9 Replies
- 6324 Views
- 1523 Views
Last post by SuperHerman
- 632 Views
