1993 940 Oil spewing out the coolant expansion tank
lindy8_man
- Year and Model: 1998 S90
Re: 1993 940 Oil spewing out the coolant expansion tank
If you are sure you do not have a blown gasket, look right behind the oil filter is a oil cooler that should have a hose in and out full of coolent. I would look here as this is your oil water interface. see attached photos
- 940 oil cooler [1].jpg (21.65 KiB) Viewed 1235 times
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
- Year and Model: Lots
- Been thanked: 128 times
Bypassing this with a hose joiner would help you determine if this unit is faulty. Of course your oil will run hotter so drive conservatively.
- Hose joiner.JPG (13.74 KiB) Viewed 1231 times
OH I get it so you guys are saying my oil cooler may have taken a dump...and thus release oil into the expansion tank? my car is NON TURBO... does this matter?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
I will post pictures tonight
You really need to work out which fluid is contaminating the coolant. Try the rag test on concrete and see if the concrete stains. Otherwise send a sample away for lab testing.
Way too much labour/cost involved unless you really know which fluid you're dealing with.
OK...here's what I found out tonight. It wasn't the head gasket at all. It was a clog in the expansion tank hose leading to the radiator, which I guess, forced a lil bit of oil back into the return hose of the expansion tank. the clog was from Bars Leak I put in 2 weeks prior.
So what I did was bought a new 3/4 inch heater hose, cleaned out the expansion tank, hooked everything back up to see if I could see "bubbles" in the expansion tank after warming it up. )THIS is the true test to know if your head gasket is toast)....NO BUBBLES!
...So while I was in there I swapped out the old ECT(for fuel injectors), but couldn't get the ECT(for the dash guage) out yet, so I hit that one with some PB Blaster. Took it for a spin and I can feel the difference in power band and pick up speed. It used to "stick" before a shift change, no more. I guess that ECT for injectors was the problem there.
So far so good. no overheating issues, nothing.
**WARNING!!!**** - DO NOT USE BARS LEAK ON THESE CARS, IT DOESN'T WORK!. When I got in there, I noticed a lot of "clumps" of bars leak coming out of the heater hose and right at the opening of the radiator. Right before my breakdown I used this junk thinking I was sealing a hole in my heater core.
I believe this stuff is what caused my overheating issue and oil in the expansion tank in the first place. I'm sure it was blocking the passage of coolant/water and thus forcing trannny cooling oil back into the tank. I learned the hard way on this one.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I learned 25 years ago not to use Bar's Leak that is in the pellet form. I had a leaking seam on a brass heater core. The heater core plugged up solid after using the Bar's Leak. It was so cold out that the windshield would ice up on the inside while driving home after the heater core plugged. I removed the heater core, cleaned it out with The Works toilet bowl cleaner, soldered the seam, and put it back in.
1988 Volvo 760 Turbo Wagon
Turns out it was the head gasket after all. I let it sit idle running for 15 minutes and the oil came back to the coolant again. so I'm doing a head gasket repair on this one.
Did you bypass the oil cooler first? A head gasket's a huge job to undertake without eliminating other possibles
