S40 Shifter light
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS.
First of all you'll need to remove the center console panel: Next, follow the last part of the instructions in the file below: I am also adding the how-to for the front center console section if you need to also replace the mode light in the gear shift panel:
AlienJulius
- Year and Model: 2004 s40
Hi i have an 04 S40 and spilled soda on the shifter, now the shift-lock sticks. how do i get at it to clean it out?
thanks!
-Allen
thanks!
-Allen
Just replaced mine and took some pictures, hope it helps other members.
My car is 1999 V40 2.0 (RHD so light bulb is located on right side)
Loosen the only screw, and pull and slide the panel out. The bulb holder is located underneath the 'N' position, slip your fingers inside the console and pull it out. I don't know the part number but this is how the bulb looks and its size. I wrapped the bulb with tissue paper and pull it out with a plier.
fcth
- Year and Model: 2006 S60
Thanks for the info. Just replaced the one in my 2003 S40, and this info was a big help.
I used a C&K Components 1.90120.0120000 bulb which I ordered from Digikey: http://www.digikey.com/product-search/e ... maction=on (watch their shipping, anything other than USPS is really expensive.)
To get to the light, I removed the side panel like in chitin's photo, as well as the piece of plastic around the shifter so that I could see what I was doing. You can get to that by removing the rubber tray in front of the shifter (it just lifts off) and then releasing the two plastic clips underneath it. Those were pretty stiff and I had to pry them with a screw driver. I did them one at a time, which makes it easier since the piece can slide a bit. Once they are off you can just lift the cover out so you can see where the bulb socket is.
Do you know if this bulb is the same for a 2000 S40? I cannot really tell from what's on the digikey website. Thanks!fcth wrote:Just replaced the one in my 2003 S40, and this info was a big help.
superdeluxe
- Year and Model: 2003 s40
just replaced this shifter indicator bulb and the cigarette lighter perimeter light in a 2003 volvo s40. the bulb used for both was the 2721 or 2721LL available at oreilys auto part stores (usa) $5usd for 2 incandescent bulbs. the socket type is t5. the fit and length was a perfect match to oem.
- 7921 Views
Last post by oragex
- 829 Views
Last post by R-CAMPO
- 2849 Views
Last post by Brucebo
- 875 Views
Last post by StillTrying
- 3453 Views
Last post by VolvoRollo
