PB Blaster vs. Kroil
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
Spinall4
Year and Model: 2006 V70R
Re: PB Blaster vs. Kroil
Post by Spinall4 »
Does it need to be any type of specific ATF or any will do in the ATF 50 percent Acetone 50 percent mix? I think I have both of those in the shop already.
04 VR M66 Manual Trans: Parting Out
06 VR GT Sonic Blue/Gobi
94 300 ZX TT: M/T
Ben850
Been thanked: 7 times
Post by Ben850 »
In my desperation, I will be changing the rear calipers no matter what.
I will give tis stuff a chance. The CRC Freeze-Off.
Not vouching until I see the results.
It makes sense to throw liquid "cold" into the mix.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I posted up the original report below. It looks like the test was done on 1/4" diameter dowel pins press fit into 1/4" diameter holes drilled into low carbon steel. Salt and heat were used to accelerate corrosion. Then the parts were soaked for 12 hours in the various mixtures. A compressometer was used to measure the force needed to move the pin in the hole.
