1998 S70. Tire size question
Dfischer2868
- Year and Model: S70
I was wondering if I can swap out my 195 60 15 tires with 195 65 15 tires? Wondering if they'll rub. not concerned about speedometer issues. Thanks!
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
No worries.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Tires 101:
P = Passenger Tire
195 = Width...in this case 195 mm wide
65 = aspect ratio....In other words, the sidewall is 65% of 195
15 = Obviously size of the rim
Your tire will be a bit taller than the original spec and may give you more cushion on bumps, but will reduce your agility. I went the opposite way with my 850. I have P205/55R15s. They are a little wider and about the same height as the O/E specs.
Good Luck
P = Passenger Tire
Good Luck
- Has thanked: 292 times
- Been thanked: 765 times
That's about a 3.2% oversize (e.g. http://www.tacomaworld.com/forum/tireca ... -195-65r15) and they may rub on the liners, but not on the fender itself. I have run bigger snow tires than that (215-55-16 or 4.3% oversize) on an 850 and they rub on the liners at full lock, but not on the fenders. The amount of rub was not an issue - it will be fine.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
_
Have a set of 2003 V70 rims with 195/65/15 on my 98 S70 T5. The OE tires were 205/55/16. There was a slight rubbing on the fender liner but after dialing the TOE to approx. 0 and tightening up the liner have not had a problem going on 2 years.
_
_
- 14 Replies
- 3674 Views
Last post by Matt88ch
- 1385 Views
Last post by precopster
