1995 855 Wheel alignment issues (still chewing up tires)
house of SIPS
Year and Model: 855 1994
Post by house of SIPS »
Car in question is a '95 850 Turbo 5 speed, D2 coilovers, with 215/45-17s on it. All suspension components are new. Has anyone played around with wheel alignment specs that differ from the dealer specs? I drove my car for a year and a half on IPD springs with eyeballed alignment and it hardly wore the tires. After I installed my coilovers, I had a dealer alignment done, to perfect specs, and its shredding the outside edge of the front tires. It seems like 0 degrees of camber in the front is part of the issue. Any insight would be greatly appreciated, I'm sick of trashing tires.
Ben850
Been thanked: 7 times
Post by Ben850 »
I see this is your first post.
What is the history of this car? Introduce yourself?
People have been known to "troll" or fish.
What is the dealers explanation for your issue?
What is the purpose of this car? Why the suspension modifications?
Clarify your purpose for inquiry.
No honest inquiry would be denied here.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
_
With stiffer suspension and O Camber you should get inner edge wear. Outer edge has to do with Positive Toe or Toe In.
http://www.autozone.com/autozone/repair ... 5280049b50
The tires are either Toe In, rubbing against the fender or from very aggressive cornering?
_
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Go - 1.0 degree on front camber on both sides instead of 0 degree.
85 GLH, 367 whp
00 Insight, 72 mpg
house of SIPS
A good friend of mine is a tech at Volvo of Tacoma, so there was no explanation, he aligned it to specs and sent me on my way. It drives great, just eats the outside edge of the tires. I was thinking of going 1-1.5 degrees of negative camber on the front to see if that eliminates the problem. I've had a few 850s, stock and lowered and all of them ate tires when set to factory specs, my friend said the same thing.
Alldata says the alignment specs for the front are -1 to 1 degree of camber with 0 being optimal and 1/3" of toe in. Maybe I'll try reducing the toe a little bit and add some negative camber and see if that fixes it. Good thing my alignments are free.
Suspension modifications were simply because no lowering springs go low enough for me. It sits on the tires now and looks great. Purpose of the car it to annoy Mustang, Camero, and lowered Civic drivers. It has an 18T turbo, N/A cams, N/A throttle body, ported head, ported intake, ported exhaust manifold, ported exhaust housing on the turbo, IPD intake spacer, 3" exhaust from the turbo back, ARD Blue Tune and I'm sure some other stuff I'm forgetting. Oh, and the manual swap. Thanks for the help,
Chris
Ben850
Post by Ben850 »
Sounds like a fun car Chris.
Good luck with the tire issue. I would imagine while operating at the lowered position it automatically affects the camber.
Edit: Give this a try Chris. I've seen these available on some performance sites. They adjust camber from the top strut mounting point for lowered/Racing vehicles.
Race Ready Wagon2.jpg (60.83 KiB) Viewed 1059 times
Adjustable camber strut  mount
Race Ready Wagon4.jpg (43.8 KiB) Viewed 1059 times
Race Ready Wagon.jpg (48.52 KiB) Viewed 1059 times
Race Ready Wagon3.jpg (64.66 KiB) Viewed 1059 times
Pretty nice setup I saw in another post. I guess this car is for sale.
Ben850
Post by Ben850 »
I had added a response to my previous post whereas I should have put it in a new one.
I guess that car is for sale as mentioned in another post. It looks a lot like mine from the outside.
All I need is a roll cage now.
house of SIPS
I've got those same coilovers with the camber plates. My camber is very adjustable, just need to figure out where to set it.
Ben850
Post by Ben850 »
house of SIPS wrote:I've got those same coilovers with the camber plates. My camber is very adjustable, just need to figure out where to set it.
Ok. It sounds like you are in experimental mode.
Post back your results.
Good luck.
