1995 855 Wheel alignment issues (still chewing up tires)
house of SIPS
- Year and Model: 855 1994
Car in question is a '95 850 Turbo 5 speed, D2 coilovers, with 215/45-17s on it. All suspension components are new. Has anyone played around with wheel alignment specs that differ from the dealer specs? I drove my car for a year and a half on IPD springs with eyeballed alignment and it hardly wore the tires. After I installed my coilovers, I had a dealer alignment done, to perfect specs, and its shredding the outside edge of the front tires. It seems like 0 degrees of camber in the front is part of the issue. Any insight would be greatly appreciated, I'm sick of trashing tires.
Ben850
- Been thanked: 7 times
I see this is your first post.
What is the history of this car? Introduce yourself?
People have been known to "troll" or fish.
What is the dealers explanation for your issue?
What is the purpose of this car? Why the suspension modifications?
Clarify your purpose for inquiry.
No honest inquiry would be denied here.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
_
With stiffer suspension and O Camber you should get inner edge wear. Outer edge has to do with Positive Toe or Toe In.
http://www.autozone.com/autozone/repair ... 5280049b50
The tires are either Toe In, rubbing against the fender or from very aggressive cornering?
_
_
house of SIPS
A good friend of mine is a tech at Volvo of Tacoma, so there was no explanation, he aligned it to specs and sent me on my way. It drives great, just eats the outside edge of the tires. I was thinking of going 1-1.5 degrees of negative camber on the front to see if that eliminates the problem. I've had a few 850s, stock and lowered and all of them ate tires when set to factory specs, my friend said the same thing.
Alldata says the alignment specs for the front are -1 to 1 degree of camber with 0 being optimal and 1/3" of toe in. Maybe I'll try reducing the toe a little bit and add some negative camber and see if that fixes it. Good thing my alignments are free.
Suspension modifications were simply because no lowering springs go low enough for me. It sits on the tires now and looks great. Purpose of the car it to annoy Mustang, Camero, and lowered Civic drivers. It has an 18T turbo, N/A cams, N/A throttle body, ported head, ported intake, ported exhaust manifold, ported exhaust housing on the turbo, IPD intake spacer, 3" exhaust from the turbo back, ARD Blue Tune and I'm sure some other stuff I'm forgetting. Oh, and the manual swap. Thanks for the help,
Chris
Chris
Ben850
Sounds like a fun car Chris.
Good luck with the tire issue. I would imagine while operating at the lowered position it automatically affects the camber.
Edit: Give this a try Chris. I've seen these available on some performance sites. They adjust camber from the top strut mounting point for lowered/Racing vehicles.
Pretty nice setup I saw in another post. I guess this car is for sale.
Ben850
I had added a response to my previous post whereas I should have put it in a new one.
I guess that car is for sale as mentioned in another post. It looks a lot like mine from the outside.
house of SIPS
I've got those same coilovers with the camber plates. My camber is very adjustable, just need to figure out where to set it.
Ben850
Ok. It sounds like you are in experimental mode.house of SIPS wrote:I've got those same coilovers with the camber plates. My camber is very adjustable, just need to figure out where to set it.
Post back your results.
Good luck.
- 1303 Views
Last post by brick_and_motor
- 826 Views
