Only occurs occasionally at low speeds. Could it be a stuck caliper? I hear it on both sides of the vehicle. Check out the video
1998 S70 Strange noise when rolling slowly
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
that sounds like pads on rotors. have you had your brake pads done recently?
this sort of thing used to happen to me on my old nissan, if i didn't reinstall the little seating spring for the brake pads, or if i didn't shim up the new pads. as i recall it would go away after a few weeks, but it is really annoying.
i don't think it's anything to worry too much about. to establish that it's not a stuck caliper, drive between those cars again, and listen as you press the brake gently. you should hear the sound transition from "shh shh shh shh" to one continuous "shhhhhhhhhhh". do one side at a time, with one window open at a time.
- instarx
- Year and Model: XC70 T6 2011
Sounds like pads rubbing. there are rubber rings in the calipers that are supposed to pull the pistons and pads away from the rotors when the brakes are not engaged. Sounds like these need to be replaced. Get a caliper re-build kit or for all I know you can just buy the rings themselves.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Ozark Lee points to several scenarios, here are few: 1) parking brake pad coming off and rubbing the rear rotor; 2) the spring not holding the pad against the caliper firmly; 3) dust-shield is bent in a place or two.
TwoVolvoGuy
- Year and Model: 1999 V70 GLT
I had this exact noise recently on my V70. The rear pads were so worn they metal backing shims started to rub on the rotor. Strangely there were no warning squeaks. No damage was done but I replaced the rotors when I did the pads and shoes anyway.
- 1400 Views
- 31 Replies
- 2752 Views
Last post by tjmartin317
- 443 Views
Last post by Pennybags
- 2784 Views
Last post by MadeInJapan
- 9 Replies
- 1906 Views
Last post by Georgeandkira
