2001 s80 t6 i just replaced the breather box (pcv)
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Re: 2001 s80 t6 i just replaced the breather box (pcv)
Post by xHeart »
There is a discussion on similar issue where jblackburn points to a leak at the gasket over intake manifold, caused by the loose bolt creating vacuum.
This bolt is located close to the rear intake cam. It suggests to re-torque the bolts.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
loball86 wrote:So is the sound coming from the etm a good thing then?
It should sound like a click when ignition is turned on then a whine then another click at around 6 secs then the sound ceases. Normal operation.
loball86
Year and Model: 2001 s80 t6
Post by loball86 »
ok so i just replaced the intake manifold gasket it was worn and super thin and i replaced a bolt that was missing in the intake manifold while i was re assembling i noticed one of the wires to the sensor thing in the timing belt area the silver housing (isnt that the water pump) was almost completely severed looks like it hit the timing belt would that cause the effect im having?
xHeart
Post by xHeart »
loball86 wrote:ok so i just replaced the intake manifold gasket it was worn and super thin and i replaced a bolt that was missing in the intake manifold while i was re assembling i noticed one of the wires to the sensor thing in the timing belt area the silver housing (isnt that the water pump) was almost completely severed looks like it hit the timing belt would that cause the effect im having?
Picture(s)?
loball86
Post by loball86 »
its the sensor side of the harness for the coolant temp sensor right next to cyl #1 and the timing area it has 2 grey wires going in and 2 wires coming out other side of harness connector think there red/brown
Bluevanacd2005
Year and Model: 1983 760
Post by Bluevanacd2005 »
I think that sensor is the temperature sender. If the ECU isn't getting an input from it, it probably won't run right because it won't know the temperature of the engine.
Spenser
I like curves on my women, not my cars
